Old 06-06-2010, 04:47 PM   #1
Puglia10
Show me your 3/5 or 4/6, some questions too!
Hey everyone, I'm going to make a build thread soon, but just bought a 1980 swb c10 in a million different pieces. He included DJM drop spindles and a flip kit. He said its good for a 3/5 drop, which my search confirms, I think? Do I need different coils? Cut the stock ones? Anyone mind showing me their 3/5, how they did it and wheel/tire specs? Also some 4/6 or lower if you have them too, and how you did it/how could I go lower if I wanted to? Thanks a lot!
Puglia10 is offline   Reply With Quote
Old 06-06-2010, 05:31 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Show me your 3/5 or 4/6, some questions too!
the first one is 3/5
2nd one is 4.5/5
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-06-2010, 05:36 PM   #3
Puglia10
Thank, looks better with the front lower....i was afraid of that, haha! how did you do it? Keep em coming!
Old 06-06-2010, 06:18 PM   #4
baclay9
You could just add some 1 or 2 inch drop coil springs to the spindles you already have. Or you could cut a little off of your stock coils.
baclay9 is offline   Reply With Quote
Old 06-06-2010, 07:28 PM   #5
3r!c84
Badass
3r!c84's Avatar
i cut 3/4 of a coil off the springs
-00 Saturn 5spd
1/4:13:90
Old 06-07-2010, 12:16 PM   #6
Puglia10
okay thanks. anyone got any more pics? maybe different wheel/tire combos?
Old 06-07-2010, 03:09 PM   #7
Justin36
Justin36's Avatar
here is 4/6
Justin
Justin36 is offline   Reply With Quote
Old 06-07-2010, 03:22 PM   #8
Puglia10
thanks for the pic, is it on level ground? front looks higher than the back?
Old 06-07-2010, 03:31 PM   #9
Justin36
Justin36's Avatar
There is another, its more level looking in that pic
Justin
Old 06-07-2010, 03:39 PM   #10
Jonboy
Slots go on anything!
4/6 here.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-26-2010, 01:37 AM   #11
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
Originally Posted by Jonboy View Post
4/6 here.
beautiful truck man!
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 06-27-2010, 09:26 PM   #12
Jonboy
Thanks, Joe. What are the black wheels on your truck now?
Old 06-07-2010, 03:28 PM   #13
Justin36
Justin36's Avatar
yeah it was, we built that truck and didnt drive it much and sold it and the guy that has it now drives it alot, and i believe it settled a little bit after that because it dosent set the same now
Justin
Old 06-07-2010, 03:51 PM   #14
Puglia10
thanks justin36, definitely looks more level in the second pic!
looks good jonboy! looks like I might have to go 4/6, I can get the inch out of the front by cutting the coil, but how can i get the extra inch out of the flip kit, which is said to lower the rear 5 in? Keep em coming guys!
Old 06-07-2010, 04:39 PM   #15
Jonboy
It depends on your springs. My truck has 2.5" spindles, one coil cut off of the front, and a flip kit in the rear. I had the HD springs (8 leaves), so that put me close to 6" in the rear. Honestly, I was so excited to start dropping the truck, I forgot to take "before" measurements.
Old 06-07-2010, 05:29 PM   #16
silvereagle07
silvereagle07's Avatar
This is my buddys' truck with a 4/6 drop.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-25-2010, 04:23 PM   #17
Puglia10
well im leaning more towards the 4/6 with these pics guys! how can i get a 6" drop in back with a flip kit? that only does 5 inches right?
1979 c30 3+3 dually
1946 GMC
Old 06-25-2010, 04:49 PM   #18
westofb
I really hate wet sanding!
westofb's Avatar
It depends on the flip kit you have, I think some are closer to 6" than 5". You asked how you could get it lower, I guess that is like asking how to skin a cat, there are several ways. When I lowered mine, I wasn't happy with the rear and wanted to go an inch more, I just went to the auto parts store and bought a set of 1" lowering blocks, they worked just fine, and I got the extra inch I needed to level my truck. So may say not to use them for on reason or another, but they did what I wanted.
You could also remove a leaf or two from you spring packs, there is no way to tell how much drop this will give you, so you have to use the trial and error method.
You can also buy a set of lowering shackles, most times they require you to remove part of a bed cross sill to clear them. Some come with muliple holes in them so you can adjust the amount of drop you get from them.
They sell dearched leaf springs as well as lowered front spring hangers, the means to the end go on and on.
If you decide to go lower than what you get out of the flip kit, you should also consider installing a c notch as well. With just the flip kit, it would not be necessary, but if you go lower (axle moving closer to frame), it would be a worth while investment.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 06-25-2010, 04:51 PM   #19
silvereagle07
On the blue truck we installed the DJM flip kit and removed one of the springs. We did not notch the frame on that truck. Some kit offer a notch but we did not have to on that truck.
Jeramy
'85 Chevy 4X4 SOLD
Old 06-26-2010, 01:41 AM   #20
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
here is mine, 5/6
Old 06-27-2010, 12:26 PM   #21
jasonroman
jasonroman's Avatar
can you post a side shot of your truck?
the red one on here is my favorite....and im not a fan of the color red..
hoping to get mine to look like that sooner or later
jasonroman is offline   Reply With Quote
