06-07-2010, 12:21 PM | #1 |
I'm confused about my trucks rear axle
I went to napa last week to get the parts I need to completely rebuild the brakes in my truck and couldn't find a matching part for the rear brakes on my dana 60. Basically napa says that there were two brake options for the rears 11" and 13" drums, my problem is that my drums have an internal diameter of 12-1/8". Way to small to be 13" and way to big to possibly be a worn 11" drum.
As I understand it 12" drums were put on the 67-70 rears, but poking around on Rockauto's website they show a 12" drum for leaf sprung dana axles for the 2wd 72 GMCs only not the Chevs. So now I'm completely confused. It's possible that it's not the original rear, any thoughts on what I should be ordering for the rear brakes? Or how I might be able to better identify that axle? Thanks, Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
06-07-2010, 02:39 PM | #2 |
Re: I'm confused about my trucks rear axle
There are lots of different Dana rears. D35s, D44s, D60s, D70s, 5 lug, 6 lug, 8 lug, full float, semi float. Lots of "Danas." Picture and numbers will help, as well as truck specs. Get a pic of the SPID. There should be a line for the diff. That number could help.
Basically, if it is not a 1/2 ton 12 bolt, you have to do the research and tell the parts store what you need. Unless you happen to be lucky enough to has an old Mom & Pop auto parts store handy. The box stores cater to "normal" vehicles, not so much to old trucks.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-07-2010, 03:07 PM | #3 |
*** That's interesting ***
I learned a similar lesson. Turned out that the backing plates on my Dana had "FoMoCo" stamped on them. So somebody along the way felt that Ford brakes were better than Chevy brakes. I'm working on gathering parts to convert mine back to correct Chevy parts, but it's been a tough journey since so many Dana configs are out there.
Take a look at the outside of your backing plates, look for numbers, stamps, etc. Might give you a clue as to where your brakes came from.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 06-07-2010 at 03:15 PM. |
06-07-2010, 03:25 PM | #4 |
I'll post some pics tonight, it is definately a dana 60, 8 lug, posi, but beyond that I'll have to have a look. SPID?
Ron
06-07-2010, 03:28 PM | #5 |
By SPID do you mean the option sheet on the glove box door? If so unfortunately it's gone.
Ron
06-07-2010, 04:04 PM | #6 |
Project Junkie! Fishing Poor!!
The 4x4 Dana 60 (witch is GMC) has different drums and shoes than the 2x4 (Chevy or GMC) Witch one do you have? WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-07-2010, 09:16 PM | #7 |
It's a 1972 3/4 ton 4x4, and if it matters the date code stamped on the axle is 252B6.
Ron
06-09-2010, 12:56 AM | #8 | |
06-09-2010, 08:33 AM | #9 |
I'm still not sure that my axle is from the 72, it may be from an earlier model, too bad I couldn't find the BOM code on the axle shaft, that would have answered a few questions. As well, no idea how to decode the date code, 252B6 if anybody knows.
In any case the parts I mentioned above seem to be physical matches for my truck, so I'll go with those and see how it works. Ron
06-09-2010, 09:44 PM | #10 |
Well the raybestos #2052 drum appears to have been discontinued, so I rolled the dice and found a drum that dimensionally and appearance wise matches the drum that was on it, it'll cost me $15 (frieght) if I'm wrong but I'm satisified that it ill probably work. I'll post when it comes.
Ron
06-14-2010, 09:04 PM | #11 |
Some good news the drums came and it looks almost exactly like the original, so if you need a new 12" drum it looks like the NAPA #440-1202 is correct.
Ron
06-28-2015, 06:04 AM | #12 |
subscribed, good info
06-28-2015, 07:41 AM | #13 |
I kept reading 7/16" studs on the '72 and it should be 9/16" '71-up/disc brake.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-29-2015 at 08:26 AM. |
06-28-2015, 10:54 AM | #14 |
those look like the same drums as on my truck, 71 c20 with leaf and Dana 60 and yes my brakes are 12''diameter.
06-29-2015, 07:03 AM | #15 |
some guys in the bone yards ya cant trust, i argued bout my 69 gmc that it has a dana 60 in it. he said thats wrong. well my books dont lie. needless 2 say i had a hard time rounding up brake hardware 4 these 12'' setups!
