Old 06-08-2010, 11:37 PM   #1
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Sweet Chevy C10 Build
Laying 22inch Boyd's
Stock Floor BD
3/4 Frame w/ SD Drop Member
Zd Front End
Sweet 85 C10 is offline   Reply With Quote
Old 06-09-2010, 12:01 AM   #2
Sweet 85 C10
OG
Re: Sweet Chevy C10 Build
Mock up time still alot more stuff to do but felt good to see this thing laying out!!
Old 06-09-2010, 12:03 AM   #3
Sweet 85 C10
OG
The start of the build process!
Old 06-09-2010, 12:04 AM   #4
Sweet 85 C10
OG
Looks GOOD!
Old 06-21-2010, 06:14 PM   #5
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Originally Posted by Sweet 85 C10 View Post
Looks GOOD!
Your drive line looks pretty crooked.......
AVS_JASON is offline   Reply With Quote
Old 06-21-2010, 07:01 PM   #6
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Is there any advantage doing it this way?
JNJchev77 is offline   Reply With Quote
Old 06-22-2010, 02:56 PM   #7
Sweet 85 C10
OG
Yes it is! Its because if you see its tied up to the hoop its not lined up with the transmission LOL...LOL
Old 06-09-2010, 08:09 AM   #8
Shane
Shane's Avatar
the frame is underneath the rear end?
Shane is offline   Reply With Quote
Old 06-09-2010, 08:35 AM   #9
m6z
m6z's Avatar
Wouldn't that make changing a tire just about impossible?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 06-09-2010, 12:48 PM   #10
edflores
Its called an underslung frame. You only really see those on SUVs that need the floor space.
It limits your lift, but who needs lift anyways? As long as you can untuck your tire in the rear, i dont see a problem
Was this thing going to have a watts link or panhard bar? I think those upper bars dont have enough angle at all.
edflores is offline   Reply With Quote
Old 06-09-2010, 01:44 PM   #11
dv8customs
dv8customs's Avatar
Looks like a good start. Depending on the size of your 4-link bars you may need to gusset the uppers.
dv8customs is offline   Reply With Quote
Old 06-09-2010, 01:55 PM   #12
shortbed70
shortbed70's Avatar
Modified racecar frames are that way also so the rear stays under the car incase of suspension failure
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-09-2010, 02:09 PM   #13
72GREENC10
72GREENC10's Avatar
one of my buddies has the same set up and as strange as it sounds, it looks sick
72GREENC10 is offline   Reply With Quote
Old 06-11-2010, 10:18 AM   #14
Sweet 85 C10
OG
Those upper bars will have gussets! MOST DEFINATELY! Trust those bars have plenty angle on them. I liked this setup its cool because not alot of riders are doing it. THEY CALL THIS SETUP THE "SLUG"
Old 06-11-2010, 10:39 AM   #15
edflores
Check out the angle on the upper bars in the post above you. You dont have nearly as much as him. I could have sworn i warned you about this a long time ago. You are going to get rear end sway because of it. Just my .02
Old 06-11-2010, 10:05 PM   #16
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Make it 4 cents.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-12-2010, 12:24 PM   #17
Painter D
Painter D's Avatar
Here we go again.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 06-11-2010, 10:49 AM   #18
Sweet 85 C10
OG
We did a truck about few months ago using the same measurements not exactly same rear setup and the truck drove pretty good no sway at all. I understand what your saying even if I had to add a Pan Hard bar I will.
Old 06-11-2010, 10:53 AM   #19
Sweet 85 C10
OG
The way I had my orignal setup about 2 years ago was totally wrong! I messed that thing up big time, about a year ago I decided to get a Firewall back chasis made stock floor BD and I feel much better about it.
Old 06-12-2010, 02:11 PM   #20
Sweet 85 C10
OG
Nothing Positive Comes from this forum I swear!!! This wont work that wont work but whats funny is that this does work! I would sound like a hater if I started calling people out here on this forum. If nothing positive can be said then dont say it! Theres alot of stuff on certain peoples builds that I can pick on and those people are the ones commenting on my build.
Old 06-12-2010, 02:41 PM   #21
LONGHAIR
If you really belive that, you are reading in the wrong places.....but in this medium, things come-off stronger than they would in person.
When someone posts a picture, you generally get it one way or the other, everybody loves it or has negative comments. There is no in-between because people who would have been neutral won't bother to post it.
Some of the "negatives" are actually constructive comments.....If they can be taken that way, rather than being offended.
There is definately a place for innovation/experimentation, but the "tried and true" things exist for a reason...they do work. Now that is not to say that they work at extremes though, that is the point of modification. You do have to maintain the basic parameters, if for no other reason than safety. Thinking too far outside the box gets tricky.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-12-2010, 02:51 PM   #22
Sweet 85 C10
OG
Actually you put it right in your post! Obviously its a matter or opinion but I have found that in some peoples posts its more of a drama driven opinion people creating more hipe over something that needs no hipe. Everything is a matter of trial and error yes, but everyone seems to think they have the right and most correct answer for something like custom fabrication which is unique in every way. Yes keeping the safe parameters is reccomended as I said in my previous post if need be I will add a panhard bar. Theres just no need for the back and forth kiddy hipe about this TOPIC that seems to happen all the time. Constructive critics are welcome but I dont appreciate the negative vibes from these posters. Only maybe 1 our of 8 posters said anything positive but when I look at the bottom of the screen to see who is on this page it seems the same people are staring at these images and not saying anything at all positive. HATER says it all! But I didint say that now did I? Well this subject is over with no drama here to those that have something positive to say go ahead if you have good constructive info then hey be my guest we dont all know it all!
Old 06-12-2010, 03:04 PM   #23
XtremeBowtie
XtremeBowtie's Avatar
What series of Boyd's are those? They look great!
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
XtremeBowtie is offline   Reply With Quote
Old 06-12-2010, 03:07 PM   #24
Sweet 85 C10
OG
Boyd 5 Star Rumblers they dont even make these anymore, tried getting a 5th one and I cant even find it. Yeah they need a good polish im running 22x10 in the rear 22x9 in the front
Old 06-12-2010, 03:17 PM   #25
XtremeBowtie
Reminds me of an Intro Vista or Ram. Might suit your need if your looking for a spare...
