06-10-2010, 01:09 AM | #1 |
has anyone swaped a 97 vortec motor, tranny and the computer stuff into 85 crew cab
are there any threads on swapping a vortec motor, tranny and all the computer crap into the 73-87 chevys? i want to do the 6.0 but cant seem to come up with the cash to get one so im going to use what i have. its a 97 silverado 4x4/ 5.7 with 4l60e... my 97 will soon be turned into a prerunner with a carbed 454 2wd tb400... heres some pics
06-10-2010, 02:02 AM | #2 |
Re: has anyone swaped a 97 vortec motor, tranny and the computer stuff into 85 crew c
I've never done the swap but it should be pretty straitforward since the 5.7 vortec is a regular old smallblock. Painless makes a standalone harness for the application so that's a non issues. The only thing might be the controller for the transmission in that I am not aware if the painless harness will handle the tranny too but if it does just plug and play. Keep us up to date on the swap, I'm interested to see how it turns out.
1978 GMC Jimmy, 400, th350, np203 with part time conversion, Fibrecraft popup camper, soon to get a 14 bolt/d44 swap 2001 Yukon XL2500, 6.0, 4L85E, 4x4, family truckster |
06-10-2010, 09:40 AM | #3 |
i thought that painless made a harness but I'm tight on cash and would like
to use the stock 97 harness if its posable... i don't see why i couldn't use it. |
06-10-2010, 03:05 PM | #4 |
I am in the process of doing this now.. i just picked up a painless harness off of craigslist there is another one on there
http://inlandempire.craigslist.org/pts/1760150898.html half the price of a new one makes things a lotttt easier i started going through the stock one i wanted to pull my hair out.. it can be done but going through it wire by wire isnt fun! i also have the PIN outs if you would like them.. |
06-11-2010, 01:49 AM | #5 | |
11-19-2010, 03:33 AM | #6 | |
Posted via Mobile Device |
11-19-2010, 08:09 AM | #7 |
You need a np241 transfer case from a 89-91 Suburban or K5. The one on your 97 comes out on the drivers side. The one on your 85 crew will probably have the wrong spline count if it's 3/4 or 1 ton, and it won't have the electronic speed sensor. I'm assuming the np241 will work with your transmission???
Posted via Mobile Device Last edited by Greenlee; 11-19-2010 at 08:20 AM. Reason: Add info |
11-19-2010, 09:29 AM | #8 | |
Thanks Posted via Mobile Device Last edited by (541)COLD_beer; 11-19-2010 at 09:31 AM. |
06-11-2010, 02:35 AM | #9 |
Hey pin outs tell you what wire does what and where its going to... here is one for a 96
http://www.lt1swap.com/1996_vortec_5.7/index.htm there is also one for a 99 you are going to have to deal with the VATS antitheft device if you do a search on google you can find a DIY on how to disable it before you pull the motor from the donor truck.. if not it will never start unless you have the ECM tuned which i would suggest anyways! Reason i got the painless harness was so i didnt pull out my own hair! |
06-11-2010, 02:39 AM | #10 |
another great place dealing with nothing but the L31 motors
http://www.pacificp.com/forum/index....0ab16dd67b34d6 |
06-11-2010, 10:11 AM | #11 | |
06-11-2010, 09:39 PM | #12 |
i do not i have a build thread someplace on here.. i havent been documenting it very well.. swapping the motor is just a small part of it lol
11-19-2010, 01:47 PM | #13 |
11-22-2010, 12:05 AM | #14 | |
02-03-2011, 02:25 AM | #15 |
