Changing air cleaner and valve Covers on Smog truck
So My truck just passed smog for the first time since I've had it
![]() Adam |
Cruzzzn' Vet
Re: Changing air cleaner and valve Covers on Smog truck
If it looks anything close to this snake pit, Good Luck! i've been down that road already and it ain't worth it
![]() ![]() Uploaded with ImageShack.us |
78 Big10 454
![]() Join Date: Jul 2008
Valve covers are no problem, since most applications I've seen allow for the installation of the PCV valve. The air cleaner is another matter. I use an aftermarket air cleaner, except when I smog my truck - then the stock set-up is reinstalled for the test. Makes life a whole lot easier.
#4 | |
I have an edelbrock air cleaner and passed smog without a problem. Mine came with the adapter to connect the hose that comes out of the driver side valve cover.
I bought from autozone it was about 35 dollars Edelbrock 14' air cleaner part number 1221
Chris
remove air cleaner and snorkel tube, block vac. lines with a plug or screw and route them out of the way or sight, then install any reg. open element of your choice, and throw on some other valve covers and be done.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Cruzzzn' Vet
Post some before and after pics when your done
