Rear end
I want to start looking for a rear end for my C10 69.
I've seen in this forum how to convert an 73-87 but I want to know if can I do with an 88 and new. One member in the forum did it? |
its all about the +6 inches
Re: Rear end
It can be done... but why? the 12 bolt is a stronger rear, still plenty of aftermarket support... no reason to swap it out IMO.
![]() Join Date: Mar 2010
Re: Rear end
Coil or leaf?
Found out the previous owner put an 88 in my '70 coil when I replaced the wheel cylinders. His welding doesn't look the greatest, but I could take a few photos if that's the set-up your looking for. |
Re: Rear end
You can use any leaf spring rear if you weld the mounts for the trailing arms and panhard bar onto it. I believe there are kits for this which give you new mounts and a longer panhard bar.
Ray |
Re: Rear end
Yes: mine is coil springs, but I did disc brake conversion and now I've five five lugs front and six back.
Grandpa in the rustmobile...
Re: Rear end
conversion axles, redrill yours 71 72 rearend or 6lug rotors
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Rear end
ok: thanks for all the information.
Re: Rear end
theres a larger axle 88 newer a 14 bolt 5 0r 6 lugs
cucharitas customs |
Active Member
![]() Join Date: Dec 2004
Re: Rear end
I've been looking into rear end info lately, Jegs sells direct replacement axles for around $200 a pair. Cheaper than another rear end, and you might make a couple bucks back on your 6 lug axles.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
Re: Rear end
Gracias Chevyblazer se que recientemente ingresaste a este forum, la verdad paso la mitad en Tijuana y la otra en Chula Vista ojala tuvieramos la oportunidad de conocernos, en este forum tienen mi correo electronico porque no se si este permitido publicarlo en uno de estos mensajes saludos.
Re: Rear end
can anyone translate that?
Re: Rear end
Yahoo, Babel fish Translation....
Chevyblazer thanks that recently you entered to this forum, the truth step half in Tijuana and the other in Insolent Vista hopefully tuvieramos the opportunity to know us, in this forum have my electronic mail because not if this allowing to publish it in one of these messages greetings. Can someone please translate that? ![]() |
#13 | |
Re: Rear end
Re: Rear end
Well: it's funny the way my message was translated.
What I said is I know Chevyblazer recently became member in this forum and I would like if is possible to know each other, and why not other members living in San diego area and Chula Vista is not Insolent that's why is Chula, do you know what it means Chula? enjoy thank you everyone in this forum |
