06-16-2010, 10:28 PM | #1 |
Your UncleBen
What is wrong here?!?!
Was checking over my new 68 and I found an issue that has to be fixed immediately! You see it? How can I fix this? Anyone have any part numbers? Of course I am talking about the Upper Radiator hose! I assume the PO installed the incorrect upper hose.
Thanks guys! CHRIS
68 C10 shortbed -- Street/Strip Last edited by SweetandLong68; 06-16-2010 at 10:29 PM. |
06-16-2010, 10:43 PM | #2 |
Re: What is wrong here?!?!
looks ok to me besides for that gash! I tried goin the same way and installing an all rubber hose like that and i figured id have the same sort of "problem" you have so i just stuck with the steel one i have that actually bends around the alternator.
Id try looking into one of those Matt
1970 GMC 1/2 Ton 4x4 350sbc SM465 NP205 |
06-16-2010, 10:46 PM | #3 |
My hose on my 71 does not bend like that maybe try a 71 hose
06-16-2010, 10:51 PM | #4 |
What?
Those metal "hoses" were found mostly on 4x4 models IIRC.
Mine had one, but it rotted away in places. Would LOVE to get another one on, so if anyone has a good one they'd part with then hit me up!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
06-25-2010, 12:12 PM | #5 | |
One foot in front of the other
http://www.persh.org/pickup/UnderTheHood.htm |
06-25-2010, 02:50 PM | #6 |
Hey SweetandLong68 I send you a personal message.
07-05-2010, 05:37 PM | #7 |
07-05-2010, 10:26 PM | #8 |
Hand Crafted C-10
SweetandLong68, here’s what I’ve got going.
1968 short water pump SBC, non-ac, 2wd. First pics are on my truck, clears the alternator adequately. Bought from parts store, per application. The 3rd picture is from my un-molested (doesn’t mean the PO bought the right hose but it does look like it would clear the alternator very well) parts truck. The next picture confirms that that radical S-curve was used. This picture is a radiator from a post-68 truck. I think both configurations would give you the room you need for your alternator. RockAuto says: Gates #20617 Goodyear #20715 AC Delco #20608x The above numbers would be for a hose like the one on my truck. IMHO-you would be better to get the right hose than mess with cobbling it together/shielding the wrong hose from harm or, gods-forbid, using a flex hose. Good Luck..E |
07-06-2010, 08:57 AM | #9 | |
Your UncleBen
Also I hear where you are coming from about using a correct fitting hose. I stated this exact thing in a previous post! I did what I had to do by protecting the hose I have now until I can get the 'mo better fitting hose. THANKS! CHRIS BTW... Got any numbers on your altenator belt? lata CHRIS
68 C10 shortbed -- Street/Strip |
06-16-2010, 10:55 PM | #10 |
Cruzin
here is my 71 hose part number is still on it 20686
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
06-17-2010, 08:59 AM | #11 |
course that is the wrong altenator mount to go with it
06-17-2010, 10:04 AM | #12 |
Your UncleBen
Clarify will ya!? Thanks
06-17-2010, 01:00 PM | #13 |
its all about the +6 inches
06-16-2010, 11:01 PM | #14 |
Here is what it looks like.
06-25-2010, 10:43 AM | #15 |
Your UncleBen
Hey man.... Do you have any part numbers for this hose? I like the way this one runs.
lata CHRIS
06-25-2010, 11:55 AM | #16 |
have never had a problem just walking into NAPA or CARQUEST and getting the right hose for a 71 chevy with a 350ci motor,might take a day or two from the regional wharehouse but lots o times right in store stock too
06-16-2010, 11:00 PM | #17 |
Metal extensions were on 4X4's. Every 2 WD upper hose I've bought were too long and I had to trim about two inches off to keep it from pinching a kink in. Maybe he took too much off when he trimed it.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-16-2010, 11:02 PM | #18 |
Hubscrub you need a shroud..You don't over heat?
06-16-2010, 11:07 PM | #19 |
Cruzin
not really but i haven't drove it alot but that is on my soon to do list also think i will go to good steel blade clutch fan not to crazy about the flex fan
06-17-2010, 12:06 AM | #20 |
Chris bring your ass by Advance Auto and bring me a box of donuts and I'll hook you up with a top hose! lmao,,,, want never forget your visits!!!
Things happen for a reason! |
06-17-2010, 12:55 AM | #21 | |
Your UncleBen
BTW I not carrying doughnuts for a living anymore! hahah I am working on Fords everyday at Dale Jarrett Ford in Indian Trail, NC. But if you want I will pick you up some frozen doughnuts from Food Lion! lmao Oh Big O...I just bought my blazer tank, sending unit and straps from Advance Auto online the other day. Got my tank today! Other stuff probably tommorrow. lata CHRIS
06-17-2010, 12:57 AM | #22 |
Your UncleBen
BTW Big O. I got a brand new set of 3.42 gears that came with my truck I think you need! They are Motive Gears 12 bolt truck gears. Let me know if you or anyone that you know might want them! I am either sticking with my 4.11 or going 3.73 . I am going with a 700R4 so I wanna keep a little gear in there!
lata CHRIS
06-17-2010, 03:58 AM | #23 |
Location: Aurora,Il ..born,raised and still live in the same house
i'd just get an old piece of hose, cut it and clamp it over the good hose so it sits on the alternator.
Then the "old piece of hose" can get the gash in it. LOL It's the poor man's way but it'll last for years.
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
06-25-2010, 03:37 PM | #24 |
It's funny but I had to do that on the lower radiator hose as for the life of me I could not get right one in there
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
07-04-2010, 02:34 AM | #25 |
Hand Crafted C-10
