Cultural Infidel
![]() Join Date: Jan 2007
How do you remove the tailgate from a '68 fleetside?
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold ![]() 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 ![]() ![]() It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
Re: How does the tailgate come off?
two bolts on each side to remove pivot blocks and then the straps just click off
20' Daredevil (Ret)
![]() Join Date: May 2003
It's been many years, but if it's like my '72, unhook the end straps and unbolt the pocket that the tailgate pivots on..... on one side. I have done the right side but it probably doesn't matter. Then lift the side of the TG that you removed the pocket, and remove the TG from the other pocket. Easier with two people.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#4 | |
Roadtrip!
![]() Join Date: Feb 2003
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
if you still want he bumper in good shape then put some towels on the bumper
Stocker is thinking of later pivot blocks. you will need two people to do this as the pivots on our trucks do not allow easy removal. You must remove 4 bolts two on each side (the pivot blocks- 9/16) and also remove the tailgate straps (9/16 as well) it is also easier to do if you remove the large rubber bumper on each side (phillips head screws). As long as therre is no dammage, lift at each side and it should come out. The lower pivot bolts are easier if the rear bumper is off but you can do it with a u-joint extension if needed.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
no need for two people if you have tools and can outthink a tailgate and make it do what you want it to do
20' Daredevil (Ret)
That's very true.... I did mine by myself. But like many jobs that involve lifting somewhat large heavy objects, it is easier with two people.
