06-20-2010, 12:39 PM | #1 |
My 54 GMC Build
I am new to the group but have been reading for a while. I was on another group but it does not lend itself to thinking outside of original or stock. You guys are amazing builders with so many great ideas.
I started this thread in the wrong area. So if you see the same pics of the project this is it. The idea is to take the coolness of the old truck and the modern ride feel of a newer model. First take the body off the frame and get rid of 60 year old technology |
06-20-2010, 12:42 PM | #2 |
Re: My 54 GMC Build
I stripped the cab down to bare metal and sprayed with epoxy primer. Not sure how long this project will take but I dont want to go back and resand surface rust |
06-20-2010, 12:45 PM | #3 |
Re: My 54 GMC Build
This is the donnor chassis with a fender. every once in a while you need to visualize your direction. |
06-20-2010, 12:50 PM | #4 |
Re: My 54 GMC Build
I bought the 93 Chevy extended cab for 700. running and driving. The front had been wrecked but I figured I would strip everything and see what I could use. The truck is 142 inch wheel base. The GMC is a 116 inch wheel base. I figured on cutting the frame and boxing the area of the joint. what I found was a factory joint just behind the front wheels |
06-20-2010, 12:52 PM | #5 |
Re: My 54 GMC Build
So I cut the weld |
06-20-2010, 12:54 PM | #6 |
Re: My 54 GMC Build
Removed 26 inches |
04-21-2020, 09:35 AM | #7 | |
Re: My 54 GMC Build
Joe 54 Chevy 3100 |
04-21-2020, 11:02 AM | #8 |
Re: My 54 GMC Build
The converter works great on turning rust to iron oxide. Then spray epoxy primer on top of that. Every attempt should be made to sand the metal with a course grit to get the best bite of the epoxy into the metal. Metal etch works great to for bonding to bare metal and then epoxy over that.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
06-13-2022, 08:50 PM | #9 |
Re: My 54 GMC Build
I miss this truck. Any chance anyone has seen it?
11-13-2024, 07:55 PM | #10 |
Re: My 54 GMC Build
Has anyone seen my old project?
06-21-2010, 06:45 PM | #11 |
Certified Car Nut
Re: My 54 GMC Build
I like that Woodie man, thats a great ride.
06-21-2010, 07:04 PM | #12 |
Re: My 54 GMC Build
Thanks. Woodies are a crazy build. There is no bondo and everything you do shows. Mistakes are costly. I did all the work on that car. Wood, metal, paint, electrical, running gear and scraps of two cars and lots of friends with spare parts. Its a sickness because as soon as I finish the truck I am starting a 49 merc woodie.
06-21-2010, 07:29 PM | #13 |
Re: My 54 GMC Build
Was it an original woodie or did you add the wood to a standard wagon? I am leaning toward a 50's Willys 4wd woodie for a project after the 64 Chevelle to kill two birds with one stone. Might do a BBEEP envoy type conversion. I have the wood working skills and enjoy working with wood.
06-22-2010, 12:27 AM | #14 |
Re: My 54 GMC Build
This car is a factory Ford Woodie. The Envoy works great. I meet a guy recently who builds AD style Chevy Woodies. A Willys Woodie looks cool. The 41 Chevy dump truck that I have in my drive way I am leaning toward a wood body sitting on a 3500 4x4 chassis. That would be a lumber yard of wood that could climb through the forest. lol
06-22-2010, 12:46 AM | #15 |
Re: My 54 GMC Build
Dude, I might have to swing by and learn a thing or two from you!
View my truck's story here: http://67-72chevytrucks.com/vboard/s...d.php?t=402996 |
06-22-2010, 01:45 PM | #16 | |
Re: My 54 GMC Build
06-23-2010, 05:39 PM | #17 |
Re: My 54 GMC Build
How about an update with pics[ATTACH][/ATTACH]
these are the original body mounts recut to fit in there new location. the bolt through the orinal bolt holes in the truck. the rear cab mounts i turned them 180 degrees and the bolt into an original bolt location. For fun I started to fill all the unnecessary holes in the body. im using the late model gas tank with the fuel pump in the tank. |
06-25-2010, 02:29 AM | #18 |
Re: My 54 GMC Build
Cut the ruct out of the rear corners. The frame is 3 inches wider so I had to remove the turn downs and move them out |
06-25-2010, 02:31 AM | #19 |
Re: My 54 GMC Build
typical front corner rust cut out and patch |
06-23-2010, 05:32 PM | #20 |
Re: My 54 GMC Build
OrrieG way to much fun. Barbq on a woodie. Sounds like a party. lol
58Patch its a funny thing my builds. My friend in the buisness says I have blind luck. He saw the woodie before I built it and said it was an impossible build with so much of the car missing and rusted. My current build he says "Your just to inexperienced to know that you cant build what your building". I say you can build anything, its your own mind and the expressions of others that get in the way. |
06-28-2010, 01:32 AM | #21 |
Re: My 54 GMC Build
Looks good, keep the pictures coming.
06-30-2010, 12:14 AM | #22 |
Re: My 54 GMC Build
todays plan was fix the fender gap. let me know what you think
07-14-2010, 09:41 PM | #23 |
Re: My 54 GMC Build
07-14-2010, 09:42 PM | #24 |
Re: My 54 GMC Build
Fenders look great. Nice progress!
07-14-2010, 09:45 PM | #25 |
Re: My 54 GMC Build
