Old 02-16-2003, 03:31 PM   #1
KEH
Better late than never
KEH's Avatar
Header paint colors
I'm debating on what color to paint my headers. If you have done yours, what has worked best?
Thanks for the input.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 02-16-2003, 03:39 PM   #2
70c10
67-72 Addict!
70c10's Avatar
I used the aluminum color 1500° paint and it always gets flaky. Paint will never last on headers. Save the money and buy ceramic coated ones.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-16-2003, 03:46 PM   #3
KEH
KEH's Avatar
Mine are coated but they look ugly. Will the paint hold better since they are already coated?
Old 02-16-2003, 03:50 PM   #4
mikep
Used to have a truck
mikep's Avatar
I have never had a problem keeping VHT paint on my headers but I do the full prep route before painting. Sandblast with crushed glass media , wash thoroughly and bake for half an hour prior to painting. Let it cool then spray 3 medium cotes. Then bake at 350 for an hour, 450 for an hour , and turn it all the way up for an hour. Yes I have an oven in my garage ... and a sandblaster. VHT is the only paint that really works worth a damn IMHO.
No truck :-(
mikep is offline   Reply With Quote
Old 02-16-2003, 04:03 PM   #5
crazy longhorn
Fabricate till you "puke"
I have sandblasted, then shot with brakeclean ...then let dry. I then use BBQ grill paint(any color you want so long as its black!). i dont drive my truck daily, or in the wet but have found the paint to hold up for a couple seasons before repainting. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-16-2003, 04:06 PM   #6
KEH
KEH's Avatar
Thanks Mike. Sure wish I had a setup like you do in your garage. That's gotta be nice.
Old 02-16-2003, 04:20 PM   #7
mikep
mikep's Avatar
Not that big of a deal. The oven I bought for $30 at a garage sale and I have it wired directly into the breaker box in the sub panel in my garage . Works great for restoration and painting projects. I have a small sandblasting cabinet at home and a much larger one I keep at work that I bought surplus from the boeing company at their surplus store. I keep it at work in the shop because its just too big to keep at home and we have 50 HP screw compressors there. I also have a big compressor at home which is real nice for sanding and paint work. In line sanders use a LOT of air..
No truck :-(
Old 02-16-2003, 05:19 PM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
On my 409 I sandblasted the headers when they were brand new, then brushed on Eastwoods stainless steel manifold coating and baked in an oven. After 7,000 miles they still look like the day I did them. Even brake fluid dripping on one for about a month from a bad master cylinder didn't affect it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
