66 GMC V8 frame mounts??
I'm installing a small block in place of a 6cyl. What do I need for frame mounts? Thanks in advance.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
Re: 66 GMC V8 frame mounts??
I posted before I realized you had a GMC. If it had an inline engine, just use the existing frame brackets. If it had a V-6, you might want to take one out so you can compare it with a Chevy bracket. The Chevy brackets are easy to find if you need them.
Ray Last edited by raycow; 06-21-2010 at 04:16 PM. |
60-66 Nut
As Ray said, the V8 motor mount brackets are the same as the I6 brackets. If you had the GMC V6 then you will need to change the brackets. I have several sets if you need a pair.
