Old 06-22-2010, 09:24 PM   #1
cb1965
cb1965's Avatar
sticker behind seat ?
i saw this a wile ago but never thought much of it. are this common . my truck is a '65 c20
cb1965 is offline   Reply With Quote
Old 06-23-2010, 02:22 AM   #2
Captainfab
60-66 Nut
Re: sticker behind seat ?
I don't know if it is exactly 'common' but many trucks had the Detroit Lockers installed in the HO52 rear differentials of the C20's in these years. My '66 C20 has the Detroit Locker in it.
Old 06-23-2010, 03:36 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
does the "ks-10" stand for the gear ratio?, or what ratio would be in a 3/4 ton chev, I know of a 61, and a 65 that i can get, they are both ks-10
Old 06-23-2010, 03:56 AM   #4
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I can't swear to it sitting here at my computer at work, but I'm pretty sure my '65 C10 has that same decal.
fryer1979 is offline   Reply With Quote
Old 06-23-2010, 04:47 PM   #5
cb1965
cb1965's Avatar
hey captn
is the H052 just another name for Eaton rear end or are they completely different. from what i seen online i thought the rear end on my truck was an eaton, never heard of H052.
-thanks for your replies
Old 06-23-2010, 04:55 PM   #6
JimmyFloyd
HO52 and HO72 were models of the eaton axle. they both used a similar center section and parts can swap between them. The No spin was the posi option for those eatons.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-23-2010, 05:02 PM   #7
cb1965
cb1965's Avatar
thanks jimmy,
good info. is there a definate way to tell the two models apart
Old 06-23-2010, 05:14 PM   #8
JimmyFloyd
If you want more info, I posted some good links in this thread: http://67-72chevytrucks.com/vboard/s...ighlight=eaton
I believe the HO72 has an extra bolt hole on the front of the pumpkin.
Old 06-23-2010, 10:11 PM   #9
factorystock
factorystock's Avatar
HO52= 5200lb capacity 20 series, HO72= 7200lb capacity 30 series.1965 C 20's no spins were only available on 4.57 ratios. The No Spin is notorious for wiping out pinion shafts and bearings due to racheting up on sharp turns.
factorystock is offline   Reply With Quote
