Old 06-26-2010, 08:07 PM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Side marker light fill question.
I've been trying to figure out how to put a side maker light fuel fill on my truck for a while now. Right now I'm thinking I have the wrong black plastic bucket. Could someone verify this or tell me what I'm doing wrong or what I need?
If you look here, none of the holes in the bucket line up so I can bolt them to the bedside. I know I need to weld a small fill plate in the front and rear of the marker light opening, but I still wouldn't be able to attach the bucket to it.
Any help will be appreciated.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-28-2010, 11:52 PM   #2
usmcchevy
usmcchevy's Avatar
Re: Side marker light fill question.
TTT, need some help here.
Build thread
LSx Swap FAQ index
Old 06-29-2010, 12:17 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i ditched that idea cause its so small but is cool!! take your time it will be sweet when its done..
maybe cut out the inside of the bed and make a cover..
John
1999 Toyota Tacoma 4x4
Old 06-29-2010, 03:14 PM   #4
usmcchevy
usmcchevy's Avatar
Thanks, I'm trying to keep the fill on the outside because I may be putting a cover over the bed at some point. I may end up making a bucket and welding it to the inside of the bedside.
Build thread
LSx Swap FAQ index
Old 06-29-2010, 03:50 PM   #5
john
member #16
john's Avatar
Have you seen this one in the FAQ section? It is for a step bed but the plastic part looks similar to yours.
http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
john is offline   Reply With Quote
Old 06-29-2010, 07:05 PM   #6
usmcchevy
usmcchevy's Avatar
When planning this install I probably looked at that thread a hundered times. Yet I don't remember seeing those pictures. Guess I do have the right part and I see how it works. Thanks
Build thread
LSx Swap FAQ index
Old 03-19-2012, 01:09 PM   #7
ryanmctee
ryanmctee's Avatar
usmcchevy, first off, thanks for your service. Currently I am working on my marker light install. Seems like a easy mod, but last Saturday I was ready to explode in my garage with frustration. Wondering how you made out with your fill mod? If you havent completed it yet, check this thread http://67-72chevytrucks.com/vboard/s...d.php?t=295518 I am interested in you sharing ideas or pictures on this. I definately will once mine is complete.
Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=512620
ryanmctee is offline   Reply With Quote
Old 03-19-2012, 10:00 PM   #8
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Have you thought about putting the filler behind the tail light? HuggerCST has a cool one. Then I saw this one from another member on the site. Working on my brothers truck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 03-19-2012, 10:05 PM   #9
okyankee
maybe i am dumb but is it safe to put gas in a hole that has wiring in it? especially if the wire gets exposed through wear and tear.
okyankee is offline   Reply With Quote
Old 03-19-2012, 10:10 PM   #10
JKady
Almost every fuel injected car since the mid 80's has an electric fuel pump and the associated wiring inside the tank. If the wire has the ability to arc to ground, you need to fix your wiring first of all, but also I don't generally leave my lights on while fueling up so I wouldn't be too concerned with it.
JKady is offline   Reply With Quote
Old 03-19-2012, 10:13 PM   #11
chevytruckluver
if those wires are sparking it could be a problem
Trey
72 Short Step
Old 03-20-2012, 11:07 AM   #12
usmcchevy
usmcchevy's Avatar
Thanks. I made it work by welding a tab further down the tube so it could be screwed to the inside of the bed, but it was SLOW at filling the tank. Slower than the first click on the nozzle, not enough of an angle. Right now I'm working on a filler like Hart_rod did here:
http://67-72chevytrucks.com/vboard/s...ht=filler+idea
Instead of machineing down the boat filler like Hart_rod, I have this one and just cut the plastic mounting ring off: http://www.iboats.com/Deck-Fuel-Fill...view_id.167234
I should be getting different bed sides the week..........should be anyway. When (and if at this point ) I get them on I'll post pics of the finished product.
Build thread
LSx Swap FAQ index
