Old 06-29-2010, 03:01 PM   #1
BHRS
BHRS's Avatar
BBC to SBC Swap
Hi, I have an original '72 C10 Longbox 402 BBC, A/C, PS, and TH-400 that I want to swap to a 350 SBC. I am keeping the TH-400, PS, and A/C-what do I need to do this swap? I know I need new engine mount towers and mounts, but what else will I need?
Thanks-
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 06-29-2010, 03:15 PM   #2
trusty72
trusty72's Avatar
Re: BBC to SBC Swap
ac compressor mounts and power steering mounts for a sbc. im assuming your doing it for fuel mileage?
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-29-2010, 03:22 PM   #3
BHRS
BHRS's Avatar
Re: BBC to SBC Swap
Yes I am for the most part. I have a nice original '71 350 4-bolt main engine needing a rebuild and would be the replacement when the 402 finally has to be replaced. Since the truck will be my everyday driver very shortly, I want everything ready so the 350 can go in when needed.
1972 Cheyenne C10
Old 06-29-2010, 03:58 PM   #4
kwmech
Re: BBC to SBC Swap
Originally Posted by BHRS View Post
......................................I know I need new engine mount towers and mounts, but what else will I need?
Thanks-
No you don't, you can use the same stuff and just have the engine sit where the 402 did
Old 06-29-2010, 04:01 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: BBC to SBC Swap
You'll need all new acc mounting brackets, exhaust manifolds/headers, mounts would be nice, but not needed, rad hoses, a small block fan shroud (the right mounts will make sure the right shroud will fit)... there may be a few more odds and ends too
Old 06-29-2010, 05:12 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: BBC to SBC Swap
Let me know if you decide to sell the motor and accessories.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 06-29-2010, 05:59 PM   #7
BHRS
BHRS's Avatar
Re: BBC to SBC Swap
Sorry I am going to sell of any of the original parts.
-Brian
1972 Cheyenne C10
Old 06-29-2010, 06:22 PM   #8
1-PU70
1-PU70's Avatar
Re: BBC to SBC Swap
Im getting 13MPG (city and highway combo) with my 402-700R4-3:73 rear and 31" tires.It has a roller cam, HEI, high rise cast iron intake and a 800cfm QJ from Jet. Factory AC and PS. I dont think you can do much better with a 350 and t400. I would get an overdrive trans and matched gears for the rear and you might be around 18MPG. Just my opinion. And run a Q-Jet carb.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-29-2010, 06:50 PM   #9
junkyardjohn
junkyardjohn's Avatar
Re: BBC to SBC Swap
IF YOU KEEP THE 72 BIG BLOCK TOWERS YOU CAN JUST USE THE 73 UP CLAMSHELL MOUNTS. THEY ARE MUCH STRONGER & EASIER TO LINE UP ON AN INSTALLATION. I REALIZE THEY AREN'T 100% CONCOURSE CORRECT, BUT NEITHER IS A SMALL BLOCK IF YOUR TRUCK WAS BORN WITH A BIG BLOCK, & THEY ARE A VERY NICE UPGRADE. IN MY OPINION. (BUT YOU KNOW WHAT THEY SAY ABOUT OPINIONS) I'VE HAD 6 CYL.S & THEN BIG BLOCKS IN THE SAME TRUCK & ONLY HAD ABOUT A 2 MPG DIFFERENCE, SO DON'T EXPECT A BIG IMPROVEMENT IN MILLIAGE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-29-2010, 11:38 PM   #10
capev86
Re: BBC to SBC Swap
like said above...run a q-jet (or tbi swap) and put in an overdrive!!!
if you want to get the mileage of a 350 (or better) but have more of that big block punch......make it a 377 (or 383 if it needs to be more than a hone job). i have a 406sbc w/ low miles on a rebuild to put in my 72 burb otherwise i'd make a stroker small block out of my stock 307 (it would be a 354 w/ just a crank swap).
an RV grind roller valvetrain is another great idea for daily driver duty!
capev86 is offline   Reply With Quote
Old 06-30-2010, 07:32 AM   #11
junkyardjohn
Re: BBC to SBC Swap
A ROLLER CAM IS GOOD.. THE ADDITION OF FULL ROLLER ROCKERS IS EVEN BETTER.. YOUR TALKING BETWEEN $800 & $1000 & IT WILL NOT FREE UP A BUNCH OF HORSE POWER ON A STOCK MOTOR (MAYBE 1 OR 2% AT MOST). SAME THING WITH A PERECTLY BUILT & TUNED QUADRAJET. 99.9 % OF THE GENERAL POPULATION CAN'T DO EITHER. (MYSELF INCLUDED) I'D BUY A TICKET TO SEE YOU HONE ENOUGH OUT OF A STANDARD BORE 350 TO MAKE IT A 377 CU. IN.. I THINK YOU HAVE YOUR NUMBERS MIXED UP. A STANDARD 350, .030 OVERBORE IS 355 CU. IN. ALSO MAKING A STROKER IS JUST A LITTLE BIT MORE INVOLVED THAN JUST REPLACING A CRANK WITH A LONGER THROW. 307 TURNED INTO A 354 CU. IN. MOTOR WITH JUST A CRANK SWAP?? NOT WITHOUT A MAGIC WAND. I JUST LOVE FREE ADVICE. ARE YOU MAD AT THIS GUY?? OR JUST CONFUSED?? JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 06-30-2010, 06:17 PM   #12
capev86
Re: BBC to SBC Swap
i think you are the confused one. you combine the crank from a 400 small block with the bore of a 350 and you get a 377. most people just bore it .03 over and get a 383.
i have done the calculations:
pistons from a 305 with a 400 crank makes a 325
pistons from a 307 with 400 crank makes a 354
my 406 is a 400 bored .03. remember that the 305 has tiny pistons with the 3-1/2 stroke (same crank as the 350), whereas the 307 has the 327's 3-1/4" stroke with slightly smaller diameter pistons than the 327/350 uses.
Old 06-30-2010, 08:18 PM   #13
j_cst_10
j_cst_10's Avatar
Re: BBC to SBC Swap
I have a 2002 Chevy Silverado with a 5.3 LS and an overdrive trans and get around 16-17. 18mpg with a carb'd big block and an overdrive might be stretchin it...........
j_cst_10 is offline   Reply With Quote
Old 06-30-2010, 11:34 PM   #14
junkyardjohn
Re: BBC to SBC Swap
if you want to get the mileage of a 350 (or better) but have more of that big block punch......make it a 377 (or 383 if it needs to be more than a hone job). REREAD YOUR POST. SOUNDS LIKE YOU ARE CLAIMING YOU CAN HONE ABOUT .160 OUT OF YOUR 350 TO MAKE IT A 377 CID. I DON'T BELIEVE YOU CAN . (I KNOW YOU CAN'T) YOU NEVER MENTIONED A CRANK UNTIL YOU SECOND POST, & I'M A LITTLE RUSTY AT MINDREADING. IF YOU GIVE ADVICE, ITS VERY HELPFUL TO SUPPLY ALL THE INFORMATION OF PARTS COMPONENTS INVOLVED, JOHN
junkyardjohn
DON'T RENT U-HAUL
