06-30-2010, 08:50 AM | #1 |
Can I pull a pontoon with a 700R4?
Hi guys,
My truck is an '86 350, 700R4, 3.42. I need to pull a pontoon about 75 miles each way this weekend. Can a 700R4 pull 2800lbs of pontoon and trailer safely or am I asking for trouble. It will be flat terrain. I know not to use overdrive but still not sure if it can handle it. Any suggestions? |
06-30-2010, 08:51 AM | #2 |
dang its hot
Re: Can I pull a pontoon with a 700R4?
should be ok if the trans is in good shapr...do not use OD
06-30-2010, 08:54 AM | #3 |
Rottenwood Garage Member
Yes....no problem.....avoid OD if possible. If it is going to be a regular thing put a trans cooler on it.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
06-30-2010, 09:22 AM | #4 |
Getting Old; Going Broke
Pulling is usually not the real issue, stopping is where the problems always arose for me.
06-30-2010, 09:27 AM | #5 |
Great point!!!.........pulling heavy loads without a brake controller, trailer brakes or surge brakes not only is against the law but dangerous. I flat spotted my share of tires before i learned and put brake controllers on all my stuff!
06-30-2010, 10:02 AM | #6 |
DO NOT use overdrive. With a 3.42 gear you can run 65 without running the engine too hard. Just take it easy and you will be fine.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
06-30-2010, 10:16 AM | #7 |
Location: Where I come from, it's cornbread and chicken...
I tow with my 700r4 in OD all the time. It's only 2800 lbs. I wouldn't worry about it a bit if it's running fine now. I would make sue that the torque convertor is locking up. If it's not then there will be a lot of slippage that will build up heat. Your truck should already have a tranny cooler in the rediator but better to check. I really wouldn't worry about it. I've towed 12k on the highway with the setup in my sig with the 6.2 and it has a 700r4 behind it. That was two years ago and it's still running strong
06-30-2010, 11:44 AM | #8 |
Thanks for the replies everyone. The motor is a stock rebuilt 350 from an '89 with 26k on it. I am not at all worried about it. The trans seems to be in good shape. It shifts nice and has never leaked a drop and every time I have changed the fluid it has never been burnt. Not sure if it has ever been worked on but I do know the torque converter lock up is working so I will take it easy and give it a go.
06-30-2010, 05:26 PM | #9 |
Salty Sailor
i towed a 7200 lb trailer full of sand and my 700 r4 did just fine
86 c-10 Custom Deluxe Savannah, Georgia |
06-30-2010, 05:55 PM | #10 |
One shot, one kill.
Make sure trailer brakes are up to snuff, especially if they are surge brakes. Adjustment is critical to proper operation. I've seen to many surge brake trailers cause a crash rather than prevent one because adjustment was way off. I have also seen them "chirp" the trailer wheels on a wet road makeing the trailer whip and sometimes spin out. Also with surge brakes you don't have the option of using just the trailer brakes on steep downgrades to keep it behind you instead of trying to pass you. I never had much faith in the electric brake until I pulled one, now I'll never use one without them. They will actually stop the truck and trailer loaded in an emergency if you loose truck brakes. Don't worry about the trans or eng, it'll move the 20,000 pound total weight just fine if ya stay out of OD. Just keep in mind, even with a smoking rubber stop your going to need between 200 and 300 yards to stop. Keep your following distance at 4 seconds or more. 10 years of 18 wheelers you see alot of crap and learn the difference between a driver and an operator. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
07-01-2010, 01:10 AM | #11 |
When my Burb was still stock, I towed a Chevy Celebrity from Florida to Ohio, the 700r4 and half ton brakes did just fine the whole way.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
07-01-2010, 02:03 AM | #12 |
like James said stay out of OD it will mess one up really bad
how do i know? don't ask |
07-01-2010, 03:34 PM | #13 |
I really hate wet sanding!
I would say no, you are going to need the entire truck!
I can't believe I got to be the first smart a$$ to post!
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
