07-04-2010, 05:40 PM | #1 |
What?
Home made burb headliner
Well, I have finished most of the hard work on my head liner board project.
I still want to replace one panel, since it is just barely working. I need to cut out a new one that is about 1/2" wider length wise, but I think it will hang in there for the up coming Brothers truck show. What do you think?
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 07-06-2010 at 08:49 PM. |
07-04-2010, 10:14 PM | #2 |
Re: Home made burb headliner
Looks great. What did you use to hold the panels up on the metal cross bows? Are those the stock plastic/chrome pieces painted white or something else?
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 07-04-2010 at 10:15 PM. |
07-04-2010, 10:19 PM | #3 |
What?
I had to ditch the OEM metal cross bows... They just made everything much more difficult.
With the material I used, there is quite a bit of tension to hold everything together. I really tried to go all out using the original bows, and even spent a wad of cash on good original plastic retention strips. But in the end it just didn't work out.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-05-2010, 12:02 AM | #4 |
what material did you use? it looks great and I need to try something with mine.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
07-05-2010, 12:15 AM | #5 | ||
What?
This sheet board was pretty good to work with, flexible enough to work with and gives a little with warm temps. When I did mine, I laid out the 4x8 sheets on my driveway in the sun. After that, they were "easier" to work with, but I was by myself so if you have a helper you will be so much better off! I made a lot of mistakes/damage just because of the floppy-ness of these things, and being on my own trying to get things to fit right. If only I had two or three other arms!
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 07-05-2010 at 07:24 PM. |
07-06-2010, 12:26 PM | #6 |
Nice work as usual! Thanxs for the pics.
07-06-2010, 08:45 PM | #7 |
Glad the template was somewhat helpful.... and you put up the same kind of FRP material that I had in mind. Looks good. Gives me inspiration. Thanks for sharing! aka "Mr. Meyers."
07-06-2010, 09:00 PM | #8 |
thanks for the info. I have got to do something eventually.
07-07-2010, 08:22 PM | #9 |
Junk Yartist
subscribing so I can remember this
07-15-2010, 01:26 AM | #10 |
Turned out real nice, has a clean look. Good job!
Doug '72 GMC K2500 Suburban 4x4 |
07-15-2010, 09:20 AM | #11 |
Wow, that came out looking real good.
07-16-2010, 01:30 PM | #12 |
Not bad, looks real nice!
Thats the very same material I used back in 2001 on BIG ORANGE However I had to go with the original OEM bow's! The rig got 3 best interior awards in 2yrs! I also put insulation board behind the headliner for sound deadning!
Things happen for a reason! |
07-16-2010, 02:10 PM | #13 | |
What?
It will be a long time before I get any kind of award for best interior on my burb... Doing 3 bench seats is pretty expensive, and on top of that no one is making OEM style covers for a 68 burb yet. So I am rockin the horse blanket cover in the front, and dirty original covers on the back two for who knows how long. I got the head liner issue squared away for the most part, and all the side panels done in OEM color and pattern. Plus my carpet, though nice is the wrong color. One of the pitfalls of buying stuff for a burb, before what you actually need is made like they are now a days. I learned a lot about what actually people are impressed with at truck show's at the last Brothers show, and mostly stock K20 burbs are not one of them. Maybe it was the show, and what was being promoted. Though I built my baby for me, so who cares!
06-05-2011, 05:03 PM | #14 |
hi, I am in the middle of trying to fix my headliner in my 86 K20 too...thankfull I found this thread. I am Dutch, so can anybody please explain to me what this FRP material is? and how exactly did you attach the panels to the roof?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
06-06-2011, 12:18 AM | #15 | |
What?
For your 86, I don't think it may be a good solution. Since on the earlier models like my 68 or the 67 model year, the original headliner was a thin card board like material and it was secured mainly by sitting in a channel along the inner wall of the body. Then there was a single screw in the roof section, that screw helped keep the board bowed up against the ceiling. The 86 models I THINK used a thicker material, and had foam rubber backed material glued to the board. If there is a channel that the original board fit into along the sides, you may be able to make something like what I did work for your truck.
06-05-2011, 09:52 PM | #16 |
Champagne Taste on Beer Budget
That's an excellent job!
I plan on adding a second headliner lamp in the back of mine. In fact I may duplicate what you have done on your headliner and it looks very slick!
Coming Soon: Project 1970 Country Truck |
06-06-2011, 01:54 AM | #17 |
he thanks man!
here's a picture from when we just got it. still a big mess in the back. and here is a pic where you can see how the trim pieces (top right tan colored) hold the headliner in place. So I do think your solution might work for me. Just need to look into this material here in the netherlands. was it expensive these frp panels? hahahaha, and now I understand my own misunderstandig. I read 86 in your sig, while it is 68...but still,great writeup, should be made sticky for more people.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS Last edited by kikkegek; 06-06-2011 at 01:56 AM. |
07-03-2011, 10:22 AM | #18 |
What?
I got everything from Lowe's.
Just need a jig saw, measure tape, and a measuring square.
07-04-2011, 09:04 AM | #19 |
Creative, good job.
1969 Chev Longhorn Custom Camper 1955 Buick Century Estate Wagon 1963 Buick Riviera 1953 Chevy 3100 Panel 1967 C-20 V8 4 speed 1951 Willys Jeep Wagon 1956 Chevy Suburban |
07-04-2011, 02:49 PM | #20 |
Great looking headliner!
07-04-2011, 09:15 PM | #21 |
Awesome work! I'm going to save this one for when i do mine.
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
08-03-2011, 10:58 AM | #22 |
That is a very nice job on the headliner. So little original stuff is out there that original is rarely an alternative.
08-03-2011, 01:11 PM | #23 |
I would think that someone could repop an original headliner at a reasonable price. That is if there is a demand.
72 chevy 3/4 ton 4X4 |
08-19-2011, 11:11 PM | #24 |
I sure would like to have a original new repopped headliner.
08-26-2011, 10:00 AM | #25 |
Some great info here I will use very soon on my 68.
Big Thanks for posting this!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
