![]() Join Date: Dec 2008
WTB Main shaft for Rockwell t-221 Transfer Case
I knew going into this rebuild parts for a Rockwell were hard to come by. Now I'm at the point where either I find a used main shaft or find another complete working 221 or switch to NP205.
Rockwell Standard T/Case Model: T221 N3 Ratio: 1.94 Serial: 12 67-034 Maybe someone down south who has a 4x4 but didn't have to used the 4wd much? Fingers crossed! |
Re: WTB Main shaft for Rockwell t-221 Transfer Case
You need to join pirate4x4.com/forum and post in the WTB section....somebody there will have what you need.
Personally, I'd switch to a different t.c. Last edited by Jim_D; 07-07-2010 at 03:46 PM. |
Man i thought i was the only one with a rockwell case..I was lucky ,i was in Harry's U Pull It in Hazelton PA and there was a 69 3/4 4x4 there with a rockwell case..I bought it for a spare in 1995. I am running the rockwell in my 70 4x4 blazer with the 69 K/20 axles. Check with 1tonmudder on ck5 board. he may know of another one. I do not want to part with my spare just yet..If the $$ is right i may.
I even have a 4speed with an factory aux overdrive 3 speed trans behind it (divorsed) Was in a 1967 GMC TON moving box van. Last edited by 70BLAZERX2; 07-07-2010 at 06:33 PM. |
Active Member
![]() Join Date: Dec 2004
Patsfan, I have an R221 and np205 within driving distance from you, 08015 in NJ. Your choice $75. Rockwell came out of a '69 Blazer, P.O. said truck ran and shifted fine, but no guarantees, 205 came out of a running '71 Blazer. Can get pics if your interested.
Hey i lived in 08070 for years and had these trucks when i was there. From 1971 untill 1995 i was in jersey..I bought a 68 anni 8 foot gold bed with wood floor from a yard on the way to bridgeton on that long straight away where the concrete was broke every 100 feet or so...it was like thump,thump,thump...for miles out there...I cannot remember the name of the yard..And also holliday's in salem...Went there alot too. I friend of mine had a 1971 2wd blazer in pennsville...
#6 | |
![]() Join Date: May 2007
I have two rockwell t cases also.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Yes pics would be good.
Does anyone know the difference between the T-221 and R-221? Dually jams any chance you had either of those apart? LOL! |
Active Member
Patsfan, No R-221, my bad abbreviation for Rockwell, it's a T221. Will try to get pics tomorrow.
Thanks. You're about 2.5 hours away.
If anyone has a 221 apart could you PM me pics? Appreciate the help everyone! |
![]() Join Date: Mar 2003
I have a465/221 adaptor that has been sitting around for a while, has a shaft still stuck in it. If anyone of you guys is interested...............50.00 plus the ride
#12 | |
I need a rockwell sleeve 3 3/8 long 2 inches outside dia. Last edited by 70BLAZERX2; 10-26-2010 at 12:58 PM. |
Can you post a pic? Thanks dude!
both of my t-cases are still a complete set up. Lets see how the deal goes with 6t727t2.I will pull one apart as a last resort.
#15 |
Guys I'd like to thank you all so much for the help. A member PM'd me with a fantastic set of input and out shafts that I pulled the trigger on already. I still can't believe it!
