Old 07-11-2010, 11:12 AM   #1
mikey531
mikey531's Avatar
Should I or not?
I have been arguing with myself for about a year now on whether to move my engine forward a little. It is very close to the firewall and I think it is because some previous owner used the 6 cylinder mounts on the 350. I have decided I do want to move it, so what is the easiest way to solve my problem?
Thanks !
mikey531 is offline   Reply With Quote
Old 07-11-2010, 01:43 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Should I or not?
Get a pair of V-8 frame mounts and put them in the forward holes. Then you will have to shorten the shift linkage rod, move the shifter pivot bracket on the frame, move the trans crossmember forward, find a longer driveshaft, re-bend the trans cooler lines, adjust or lengthen the throttle rod, lengthen the exhaust pipe or pipes, maybe shorten the radiator hoses, and lengthen the heater hoses, and fuel line from the tank and a few other things I forgot...
LockDoc
Leon
Old 07-11-2010, 01:49 PM   #3
cdowns
cdowns's Avatar
if you have a lazyman rubber line from pump to carb put a metal fuel line in b4 the fire
Old 07-11-2010, 02:18 PM   #4
mikey531
mikey531's Avatar
Umm I do have a steel line going to the carb... Where do you see rubber line?
Old 07-11-2010, 03:12 PM   #5
cdowns
cdowns's Avatar
i didnt say you had rubber fuel line did i??
Old 07-11-2010, 05:13 PM   #6
mikey531
mikey531's Avatar
Good Point, no you didn't, sorry
Old 07-11-2010, 02:17 PM   #7
mikey531
mikey531's Avatar
LockDoc
I was kind of thinking only an inch or maybe an inch and a half. Can I just drill new holes in the frame?
Old 07-11-2010, 05:25 PM   #8
71swb4x4
71swb4x4's Avatar
If it works, don't fix it.
The jobs always turn into more than you think they will. Something will break, and all of a sudden you are spending more time and money than you thought.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-11-2010, 05:26 PM   #9
Shyguy
Junior Member
Shyguy's Avatar
We did not want to change the length of the driveshaft so when we transplanted a 454 into my truck that previously had a 350 we had to just let the 454 settle in and drill holes in the frame. Don't forget the lower bolt hole will either have to be drilled or the area welded.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-14-2010, 04:58 PM   #10
mikey531
mikey531's Avatar
I guess I have talked myself out of moving the engine. I seem to remember something about a smaller cap HEI dist cap? Anyone else remember?
Old 07-14-2010, 05:39 PM   #11
michael bustamante
michael bustamante's Avatar
Ive seen the smaller hei dizzy caps but I dont remember where. Skip Whites maybe? e bay, Hmmm
1967custom
michael bustamante is offline   Reply With Quote
Old 07-14-2010, 11:29 PM   #12
LockDoc
LockDoc's Avatar
The smaller ones have a separate coil instead of the coil being in the cap.
LockDoc
Leon
Old 07-15-2010, 04:17 AM   #13
Lippyp
English Chevy Owner
Lippyp's Avatar
I have exactly the same problem to the point that I can't fit an HEI in due to it hitting the firewall. In the end I've bought a pertronix conversion kit for the twin point mallory that was in there and one of their coils and will live with it where it is for the moment.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 07-15-2010, 11:50 AM   #14
junkyardjohn
junkyardjohn's Avatar
ACTUALLY... FROM A TRACTION & HANDLING POINT OF VIEW (YOU
'LL PROBABLY NEVER NOTICE IT THOUGH) YOU'RE BETTER OFF HAVING YOU'RE MOTOR (CENTER OF GRAVITY) AS FAR BACK AS YOU CAN COMFORTABLY LIVE WITH. ( IT SEEMS LIKE A GOOD REASON TO GIVE ANY OF YOU'RE BUDDIES THAT ASK WHY.) IT WON'T HURT A THING & SEEMS LIKE IT WOULD BE A BIG PAIN TO CHANGE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-15-2010, 12:11 PM   #15
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
It is more just a matter of what you prefer. Personaly I would find a set of v-8 engine brackets and move the engine forward. Thats just me though. I don't like looking under the hood and being able to tell at a glance that the truck is an original in-line truck. To have the motor centered more in the engine bay looks better to me also. It is a bunch of work to move it but worth the effort and cost to me. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
