63 c10 custom air bags f/b how to correct body roll
Hey peeps...so I have my 63 short bed with custom airbags. By custom I mean not a bolt on kit. I have front and back only...The rear is a 4 link with a panhard bar and has a custom rear clip. The front has cpp 2 1/2 and 2600 firestone airbags. It has a sbc 305/700r4 trans.The truck feels like crap on turns and even when on a straight away. On straight aways it swerves a bit .It has alot of body roll. The front has no sway bar nor shocks!...NOTE: It has a 73 chevy front suspension. What will correct my problem? shocks?sway bar? etc....I want this to be a daily driver....Also does cpp or other companys carry a bolt on sway bar.Thanks ahead of time!
Re: 63 c10 custom air bags f/b how to correct body roll
Go to your local pick a part, grab front sway bar from a 1 ton gm pickup, all hardware with it, for the rear you`ll have to buy off a site or build your own from a later model camaro, you won`t believe the differance. one ton trucks use a 1 13/16 front sway bar...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 07-11-2010 at 07:19 PM. |
Squarebody guy
Anit-Sway bar and shocks will help but if you wanna do it right you need to add 4 more valves, even if you never hit sides. Shocks will do wonders for the overall ride too.
Thanks guys. So Rich you know your Sh**T huh ?Lol. To answers to my questions.Thanks a ton....Ok so...I am definetly on a budget here so the junk yard will be my first stop..So it has to be from a 1 ton? Any year? Is it bolt on?My lower control arms have no holes for the sway bar. I probably have to drill the holes myself on the arms and frame right. Also Ghost and Rich My truck is pretty freaken low on the front. Will my shocks go that low and what should I use? Autozone over here in Cali has them for about 30 for both out the door. Will that work or do I need drop shocks. Once again thanks for the quick 411.
Resistance is Futile
You need drop shocks....any sway bar will work off 1/2ton. I agree that the heavier one would be better. CPP bars have an end link set-up that is easy to install. My 'burb is bagged with a bar and good shocks and has NO sway or weird handling whatsoever.
Do it ![]() ![]()
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#6 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#7 | |
C10 CLUB Y QUE!
just asking i have a custom airbag set up on my 65 i have shock all around and no sway bar. i do know you have to have the bags at a certain psi to get the best ride out of it not to full and not to empty. you got any pics of the custom rear clip. oh belive me the shocks makes a big diffrents |
#8 | |
![]() Quote:
#9 | |
C10 CLUB Y QUE!
and yah shocks is a most cpp has them. thats were i got mine from |
Here are some pics of the rear clip! Hopefully they uploaded.
#11 | |
C10 CLUB Y QUE!
VA72C10
![]() Join Date: Mar 2008
shocks are a definite need....but as mentioned the biggest difference after that will be more valves....not a sway bar....with only two valves if I'm reading correctly....all the air is transferring from one side to the other and will continue to do so until you get more valves.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#13 | |
8 valves and 4 switches makes every corner independent.
#15 | |
Active Member
![]() Join Date: Dec 2004
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* |
#16 |
C10 CLUB Y QUE!
i have the same thing>>
#17 |
So what do you guys think of the truck? God I miss my 22" wheels. I decided to change the look of the truck so I went with some old school centerlines wrapped in some cooper cobras..My truck sat like 4 inches lower which I think is a plus!!!
#18 | |
C10 CLUB Y QUE!
#19 | |
#20 |
Thats what I said. It looked good with 22"s but I love the old school look. The back as at full ride hight on the pic. And the front is fully slammed.The back sits like 2" off the ground when fully dropped. The front as you can see sits pretty high. I have cpp 2 1/2 spindels on the front..3" bag cup and a firestone 2600 in between. What do you guys suggest I need to slam the fron a bit more. I also removed my front wheel tubs.
#21 |
VA72C10
Is that 4 total valves? 6 would be the min if you used check valves for the rear, but 8 is ideal. Either way shocks will also make a huge difference.....
#22 |
![]() Join Date: Apr 2004
^ agreed, you need eight valves and more switches.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#23 |
Hollister, CA.
![]() Join Date: Sep 2006
If you just want FRT and BCK ... all you would need is SIX valves, a few fittings and some checks to correct the air transfer. No need for 8 valves.
Two switchs aree enough, unless you want a pancake and a front to back 'rock'...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#24 |
I hate to disagree with the chief but more than two switches will allow for fine tuning. It's not just for playing. I have seven switches , theY come pre wired. One switch for each corner, one front and one back. The last one is to air it out on all corners known as pancake.
#25 |
Hollister, CA.
Again ... I said IF all he wants is frt and back.
If you want 'seperate' control of 'each' corner, then you 'will' need 8 valves. Otherwise you can still have precise control of the truck, using 6 valves, with more switches ... just with a downward travel. Prewired switch boxes huh ?? I hate those things ... I'm ol'school man. I still make up my own panel and switches boxes. Since '88 when I was (still am) messing with the hydros ... BTW, your allowed ONE disagreement with me !!! ![]() ![]() JK, it's all good !!!
