Old 07-11-2010, 09:37 PM   #1
ranger374
Frame mod for a TH350????
will a automatic clear the stock transmission bellshousing mount on a 63 c10 frame, or do you have to remove it when using an automatic tranny????
I know i would have to make a seperate mount to bolt the auto tranny on, just wondering if you can keep the stock mount in there also, in case you ever wanted to go back with a manual??
My Build thread http://www.67-72chevytrucks.com/vboa...d.php?t=408574
ranger374 is offline   Reply With Quote
Old 07-11-2010, 11:46 PM   #2
Captainfab
60-66 Nut
Re: Frame mod for a TH350????
You have to remove the original bellhousing crossmember when converting to an automatic. For a transmission crossmember, you can use one from a '73-'87 truck, Suburban or Blazer as long as they are 2wd. You'll just have to drill the mounting holes in your frame.
Old 07-12-2010, 06:35 AM   #3
ranger374
ok thanks!! that's what i figured.
