Old 07-13-2010, 08:27 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Help identifying parts please
I am getting ready for final assembly....going through the boxes and bags of original parts and found these unlabeled... Some look to be jack and/or spare tire parts but since I've never disassembled a blazer (only a few trucks) I'm not 100% sure and not sure where they'd go. also not sure on the two large bolts with rubber grommets both sides....were they possibly suspension parts that weren't re-used with the lift kit put on? thanks...
Old 07-13-2010, 08:41 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Help identifying parts please
The blue parts are definitely the jack hold down pieces. No idea on the big washer, possible for the behind the seat spare tire holder. It might be the always missing part that goes on the hub of the wheel. The other bolts and bushings must be for leaf spring shakles or something like it.
hgs_notes is offline   Reply With Quote
Old 07-13-2010, 08:57 AM   #3
VA72C10
VA72C10
VA72C10's Avatar
That's about what I was thinking for everything. thanks.
any idea on the one big clip on the lower left corner?
Old 07-13-2010, 09:12 AM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
I don't recognize it. Could it be for holding the heater hoses together? Looks too big to be for any brake or fuel lines, I don't think it's for any wire harness. If it's for A/C hoses I have no idea. I never had a truck with A/C.
Old 07-13-2010, 09:15 AM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
I'm thinking the shackle bolts are probably the ones that hold the rear spring shakle to the frame bracket. If the springs were replaced they might not have pulled those out to save time, and just did the spring bushings.
Old 07-13-2010, 09:46 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
Thanks, they went with a complete lift kit so probably didn't need these. Thanks again for your input and fast response
Old 07-13-2010, 10:30 AM   #7
JimmyFloyd
the clip on the lower left looks like the ones I had on my suburban that held the AC or trans cooler lines.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 07-13-2010, 03:23 PM   #8
herb101
Used Register
herb101's Avatar
I'm also thinking the clip is a heater hose hold-down. Snaps in a hole on the passenger side inner fender well.
The blue brackets and springs are jack hold-downs. The boly to the vertical wall of the step up to the bed, behind the seat (driver's seat I THINK). I don't recall the arrangement, but on hook engages the circle on the end of the spring after it get stretched over the jack. The other end of the spring is bolted down and the sring runs side-to-side across the area behind the seat.
The washer is the spare hold-nut part that covers the large hole in the rim. There is a J-bolt that hooks into a strap on the spare tire bracket and a big wing-nut that screws onto it. The washer spreads the clamping force of the wing-nut over the big open center hole.
edit - here's a link on the board to the set-up on the jack hold down.
http://67-72chevytrucks.com/vboard/s...ight=jack+hold
herb101 is offline   Reply With Quote
Old 07-13-2010, 09:27 PM   #9
swyfor5
swyfor5's Avatar
The blue pieces are to hold down the tire iron behind the drivers seat on the step-up.
swyfor5 is offline   Reply With Quote
Old 07-13-2010, 10:27 PM   #10
pound41
The one clip snaps to the top of the inner fender for the heater hoses
pound41 is offline   Reply With Quote
Old 07-13-2010, 10:41 PM   #11
BLUE THUNDER
BLUE THUNDER's Avatar
Bingo!
BLUE THUNDER is offline   Reply With Quote
Old 07-13-2010, 10:45 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Thanks everyone...I'm going to save the jack and spare tire/spare parts for the next owner...and will clean up and install the heater hose clip once I put the inners in...
