07-13-2010, 04:40 PM | #1 |
72 lb battery killer
bought a brand new battery. it died within 24hrs. didnt evn hav enough juice to turn the lights on. this is the 3rd battery ive gone thru. any suggestions on y it is sucking power while the truck is off??? thanks guys!
07-13-2010, 05:31 PM | #2 |
Re: 72 lb battery killer
Does your horn work normally?
Ray |
07-14-2010, 06:02 AM | #3 |
no the horn does not work. but i have a battery charger that has an alternator checker. n it gave me a code that read the alt. was bad. could the horn relay b causin it to do that?
07-14-2010, 12:44 PM | #4 |
Then there is a good chance that this is where your problem is. Disconnect the plug-in connector at the relay and see if the drain stops. The relay itself likely isn't bad, but the wire going from the relay to the steering wheel could be shorted to ground at some point, causing the relay coil to draw power all the time. If the relay feels warm when you touch it, this is a sure sign.
Ray |
07-14-2010, 07:17 AM | #5 |
the diodes in the alt could be bad pulling off the battery when they truck is off
07-14-2010, 09:49 AM | #6 | |
You have a key off drain follow this thread to test http://67-72chevytrucks.com/vboard/s...ad.php?t=33198 the previous two posters named some common key off drains so as part of the test also unplug the horn relay and alternator.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
07-14-2010, 11:41 PM | #7 |
its all about the +6 inches
if the machine says your alt is bad... I would start there.
While the engine is running, and not charging the battery, then you are running directly off the battery and running it down, untill it is dead. |
07-25-2010, 06:31 PM | #8 |
k . i took a volt meter to my alt. its charging the battery. but ther is still a drain. any ideas fellas??
07-26-2010, 02:39 AM | #9 | |
Ray Last edited by raycow; 07-26-2010 at 02:42 AM. |
07-27-2010, 04:15 AM | #10 |
no. because i thot it was the alt. but ill give it a go tomorrow. do i unplug all three wires? i believe thers a black ,red, green???
07-25-2010, 11:07 PM | #11 |
what was it charging at... 12.5, or 13.5?
07-26-2010, 02:33 AM | #12 |
i believe it was higher round 14.5. ill have to check it again to b 100% sure
07-27-2010, 06:32 AM | #13 |
its a single plug, they'll all three come off together. Listen for a click insude the relay as you unplug it. If it cliks, then you found the problem.
07-28-2010, 06:22 PM | #14 |
Chevys Kick A$$
If your alternator is good and charging your battery then you got a serious power drain some wheres in your system. You gotta stuck going through everything I would start with simple stuff first and go from there. Do you have an aftermarket stereo stuff or light stuff in your truck that is wired to a constant hot?
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
Tags |
battery |
