07-13-2010, 09:11 PM | #1 |
Carb vacuum leak - best way to seal?
I seem to have a vacuum leak at the rear of my carb where it mounts to the manifold. The carb was rebuilt, the gasket is new and the bolts are torqued down properly. The front seems to be fine but the rear definitely has a leak. What is the best way to seal the leak? Add some gasket sealer? Go for another new gasket? Something else?
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
07-13-2010, 10:41 PM | #2 |
Re: Carb vacuum leak - best way to seal?
maybe try adding a couple thin gaskets? just an idea.
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
07-13-2010, 11:08 PM | #3 |
What kind of carb and intake is it? If your using a sqaure bore carb with a spread bore manifold such as an edelbrock performer with an edelbrock or holley square bore carb your supposed to use the square bore adapter plate to ensure a good seal.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
07-13-2010, 11:30 PM | #4 |
the pollock
by what means are you declaring it's a carb leak?
if you are spraying WD-40 or anythin like that back there to see if there's an idle change you might want to explore the rear gasket on your intake. when you pulled the carb last did you inspect everything make sure all lines not in use are capped etc?
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
07-14-2010, 07:19 AM | #5 |
Sorry, It's a stock Q-jet 4bbl. I put a new gasket on when I rebuilt the carb a month or 2 ago. I also replaced all the vacuum lines. Yes, the idle increases and smooths out when I spray some carb cleaner around the back of the carb (near dizzy) where is mates to the intake manifold. I had cleaned both surfaces before putting the carb back on.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide Last edited by C10Silverado79; 07-14-2010 at 07:19 AM. |
07-14-2010, 08:29 AM | #6 |
I'd go for the new carb gasket. But check with a straight edge to see if the manifold or the carb base is distorted. The should not have much clearance at at all.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
07-14-2010, 11:03 AM | #7 |
Is it possible you used the wrong base gasket for your carb?
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
07-14-2010, 02:53 PM | #8 |
I'm not beyond making a mistake so it's possible. i know I tried to match the old gasket with the new ones to get the right match. I guess I'll get a new one and see if that solves the problem.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide Last edited by C10Silverado79; 07-14-2010 at 02:53 PM. |
07-14-2010, 03:09 PM | #9 |
Kinda a shot in the dark here but could run a bead of gasket maker on your paper gaskets you have installed already just to make sure theres a good seal?
07-14-2010, 03:53 PM | #10 |
what i do is run over the gasket areas with a sharping stone just to smooth and level them out ... my advice is to buy a new gasket and do what i said above and see if your problem is fixed ... also i would put a rag in the intake manifold and use a vaccum cleaner to suck out all the little chips from where you sand the intake manifold
1984 GMC 1500 2WD Big plans in the making |
07-14-2010, 03:54 PM | #11 |
Rtv should not be used on a carb gasket. As stated make sure the surfaces are flat and make sure your using the proper gasket and theres no reason it shouldnt seal.
07-14-2010, 04:03 PM | #12 |
My quadrajet has a pretty strong baseplate, im not sure if it would warp easy but i've seen carbs that got overtightened and it warped the baseplate, in that case i would secure the carb in something like a vice, wrapped in a towel and file the bottom with a large bastard file.
07-17-2010, 12:01 AM | #13 |
I'm pretty sure I resolved the vacuum leak. I decided to poke around a bit before i tore the carb back off. Turns out the diaphram in the EGR valve is shot. Since the valve sits right next to the carb I think it was picking up the carb cleaner when it sprayed. I disconnected the valve and capped the line. Carb cleaner made no change and vacuum is steady. I don't know if I'll replace the EGR or just leave it disconnected.
I still have to solve my problems when motor is under a load. My first thought was the it wasn't getting enough fuel. I'm starting to think it's "Fuel Spewing" instead but I'm not sure how to fix it.
07-17-2010, 10:01 AM | #14 |
Still plays with trucks
It is possible you set the float level too high when you rebuilt it. Kind of a pain to readjust on a Q-Jet.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-17-2010, 02:43 PM | #15 |
Certainly not 'IMPOSSIBLE'. I'm going to triple check everything else first before I pull the carb apart again. I went back and read some more in my Doug Roe book which is why I'm leaning towards fuel spewing more than fuel starvation.
07-17-2010, 05:06 AM | #16 |
the pollock
fuel filter first
