Old 07-15-2010, 10:46 AM   #1
Mike Bradbury
Mike Bradbury's Avatar
Side views
Is there a specific location for the OEM round side view mirrors? My truck had the large rectangular mirrors that were just screwed into the door skin. I purchased some replacements but as I look at other builds it looks as though there are several different locations for the base. most appear to be centered directly under the wing but some I have seen are forward of it, and some are slightly behind it. The mounting hardware that came with it are machine screws like there was supposed to be some sort of backer plate with nuts attached. Since mine is a C20 with the big mirrors there was nothing on the inside of the door.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 07-15-2010, 12:34 PM   #2
swierker
swierker's Avatar
Re: Side views
I'm interested in the answer too... bump
swierker is offline   Reply With Quote
Old 07-15-2010, 02:35 PM   #3
67Slider
67Slider's Avatar
Re: Side views
When I took my door apart there was a bracket behind the mirrors that the machine screws went into.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 07-15-2010, 02:47 PM   #4
gkesseru
gkesseru's Avatar
Re: Side views
There is a backing plate, part number 67-02006 $7.00 each from the Truck Shop. You could probably make your own. There are three holes drilled in the door, with the front centered 2 3/4" back from the front edge of the door on mine.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 07-15-2010, 02:58 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Side views
If your talking about the sport mirrors then yes they have backing plate thats supposed to be inside the door. The right is not in the same spot on the door as the left.
Old 07-15-2010, 09:42 PM   #6
GruntMoanCough
GruntMoanCough's Avatar
Re: Side views
This the style your talking about?
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 07-15-2010, 09:58 PM   #7
Mike Bradbury
Re: Side views
Yes, that is the style. Thanks for the info that helps tremendously
Old 07-15-2010, 10:11 PM   #8
GruntMoanCough
Re: Side views
Glad to be of some help. The very front hole on my '69 measures 2 1/2" from the front edge of the door, on both sides.
Old 07-21-2010, 09:15 PM   #9
gkesseru
gkesseru's Avatar
Re: Side views
GruntMoanCough: In that diagram the front hole is located .86 forward from some point labeled 15, what is this 15? All of the other measurements depend on this point.
72 Fleet (died)
78 Step (sold)
00 F150
Old 07-21-2010, 10:33 PM   #10
swierker
swierker's Avatar
Re: Side views
The way I'm seeing it looks like the first hole is .86" from the front of the door and .60" down from the first crease in the door. That doesn't explain what 15 but it doesn't appear to matter what that is.
Old 07-22-2010, 11:37 AM   #11
GruntMoanCough
Re: Side views
The 15 refers to 15" back from point zero, which is the vertical flat surface between the cowl cover gasket and the engine wiring harness. The 35 refers to 35" above an imaginary (datum) line, the bottom surface of the rocker panel (not the pinchweld) is 5" above this line.
Provided your doors are aligned correctly to these references, you could use these points. I just find it's easier measure from an existing vehicle. Like I posted above, the front hole is 2 1/2" from the front edge of the door, on both sides, on my '69. BTW, the height of this hole measures 1/2" below the body line on the passenger side and 5/8" below the body line on the driver's side.
