Old 02-19-2003, 01:19 AM   #1
72gmcshorty
72gmcshorty's Avatar
Some cowl questions...
Could someone show me a picture of where the antenna cable goes through the cab (pic from outside of cab under cowl please). I don't seem to have a hole for the antenna cable. Are the nozzles for the windshield washer fluid supposed to stick through the 2 vertical slots in the cowl itself? My nozzles don't really come close to those two holes. Anyone help out here?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-19-2003, 05:51 AM   #2
lost wages
lost wages's Avatar
the antenna hole is the one right below the windsheild pillar.
lost wages is offline   Reply With Quote
Old 02-19-2003, 01:14 PM   #3
72gmcshorty
Funny I don't have that hole........have to get out the drill i guess..
1992 Gmc 2wd
Old 02-19-2003, 01:24 PM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I don't
have that hole in my cab either. My antenna hole is under the cowl area directly under where the antenna would sit....I don't have an upclose pic of that with me, but if you look closely you can see it in this pic
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-19-2003, 01:46 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
when I frenched in my antenna, in the old gas nozzle hole I found a 68 cowl off a truck with no antenna hole, came from the factory with no radio I guess, one less hole to bondo.lol
sneakysnake is offline   Reply With Quote
Old 02-19-2003, 04:02 PM   #6
Reumster
L.E.D. Freak
Reumster's Avatar
As far as the washer nozzles I highly recomend upgrading to newer style nozzles. You'll be glad you did. Origanals flat out suck.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 02-19-2003, 04:19 PM   #7
Stout72
Not my good side.
Stout72's Avatar
newer style nozzles
What newer style nozzles? Requires a new/different pump?
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 02-19-2003, 04:24 PM   #8
Reumster
L.E.D. Freak
Reumster's Avatar
No not at all. I personally used the cheezy AutoZone LED windsheild washer nozzles, they are chrome, and install very easy. You don't have to use the lights if you don't want that look. They spray 100% better, and use two sprays per nozzle, that are fully adjustable.
(406)675-8082
