Old 07-11-2001, 01:25 PM   #1
chewalla
Question 4x4 Frt Hub Diagram
Help!!! Anyone got a good diagram of front hub assembly for a '78 4x4???
'71 Chevy C10 Modified
'27 Ford Model "T"; one of the last ones
chewalla is offline   Reply With Quote
Old 07-11-2001, 04:45 PM   #2
TX_Mudder
Post
Any parts store repair manual should have that.
What are you having a problem with? It is pretty straight forward except for the PITA wheel bearing torque.
-- Mike
73 k20 6" lift 33's SM465 NP205 350
ORD this and that everywhere
Got a spare Dana60 lying around?
TX_Mudder is offline   Reply With Quote
Old 07-12-2001, 07:38 AM   #3
chewalla
Thumbs up
Thanks for the reply. Well....son took hub apart. As WE go through the learning curve to put it back together, I want to be sure all parts are assembled correctly. Some may require a special orientation for example. We have a book that covers that year model, however it does not reflect a specific diagram of the assemble..
Old 07-16-2001, 12:16 AM   #4
TX_Mudder
Post
You could always take apart the other hub and pay attention to order of assembly.
This could also be an ideal time to upgrade to Warn hubs. ABout $65 for regular warn manual hubs and $100 for premiums (not much better, just a little shinier.) They will come with instructions.
Put it together in the unlocked position. Put a LITTLE grease on the mechanism (too much will interfere with smooth operation.) Make sure the snap ring is in the groove. That's about it.
-- Mike
Old 07-16-2001, 07:16 AM   #5
chewalla
Lightbulb
Mike,
Thanks for the info. I think you hit it on the head. This IS an opportunity to look at the other side and service. Thanks
