07-18-2010, 11:17 PM | #1 |
6.0 powered square
right stuff rear disc brakes
I plan on swapping the rear drums to disc on my truck and found this kit it seams like a good price it comes rotors, loaded rear calipers, Brackets,
Hardware, Flex hoses and E-brake cables http://www.summitracing.com/parts/RSD-ZDCRD01/
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-18-2010, 11:59 PM | #2 |
BAD BOW-Silverado XST
Re: right stuff rear disc brakes
The problem with every kit is that they are incomplete. I have yet to find one that mentions or includes a proportion valve. You will need a proportion valve to make disc brakes work properly.
07-19-2010, 12:05 AM | #3 |
6.0 powered square
thanks Gerardo I was already informed on proportion valve
07-19-2010, 06:16 AM | #4 |
You did check the application right? For Chevy trucks they only show a kit for the 9" ford axle. Don't recall if you've already made that change.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
07-21-2010, 09:22 AM | #5 |
Truckin' Magazine just did a great article on a C10 Brake Conversion to disc.
78 Silverado 1/2 Ton LWB (restore) 78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse) My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128 Ellis Benus - Web Design Columbia Mo & Google Fan Boy! |
07-21-2010, 10:11 AM | #6 |
I like the Blackbirds kit; I believe Travis (TVBlazer) used it and I believe a few others on the board has used them and they like. I have spoken with Randy the owner and he seems pretty good to deal with. www.blackbirdscustomtrucks.com
07-22-2010, 01:23 AM | #7 |
60-66 Nut
I offer rear disc brake conversion brackets, and you just purchase the parts necessary to complete the installation at your local auto parts supplier. The conversion that I have that is closest to the one posted here is my D52's with the Astro rotor. The Astro rotor measures 11.61" diameter and is 1.250" thick. That's the same size as the HD rotors on these trucks. There are some nice options with the D52 calipers also. Here is a link to my for sale thread.......Check out the total cost post (#32) I made as well.
http://www.67-72chevytrucks.com/vboa...d.php?t=398352
07-22-2010, 09:24 AM | #8 |
6.0 powered square
thanks capt, I believe I'll be getting a kit from you since replacement parts will be a snap to get
07-22-2010, 10:34 AM | #9 | |
I'm sold on his kit. When I convert my 78 Silverado 1/2 ton I am going with his.
07-22-2010, 07:44 PM | #10 |
Old Heap Driver
Being able to walk up to the counter at most any parts store and ask for parts by make and model, priceless.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-22-2010, 09:30 PM | #11 |
Truck and auto performance nut
that kit from Summit is for a Ford 9"...and probably why its priced as it is.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-22-2010, 11:35 PM | #12 |
6.0 powered square
I noticed that when I saw D13 post
