Old 07-19-2010, 06:01 PM   #1
khp71
Question 3 speed swap
will a 3speed out of a 70 bolt right up to a 71 with a 4 speed? drive shaft?
khp71 is offline   Reply With Quote
Old 07-19-2010, 06:07 PM   #2
raycow
Re: 3 speed swap
It will bolt to the bellhousing, but you will need to replace the driveshaft.
Ray
raycow is offline   Reply With Quote
Old 07-19-2010, 06:08 PM   #3
Field and Son
Field and Son's Avatar
Re: 3 speed swap
Not sure of the answer, but I just posted a 72 for parts that has a three speed, shifter, and the correct driveshaft. I am just a little over an hour east of you, or could get to the Schoolhouse tavern with no problem (my Dad owns it)
Field and Son is offline   Reply With Quote
Old 07-19-2010, 06:45 PM   #4
khp71
Re: 3 speed swap
i have a 71 1/2 ton with leaf springs and a 2 piece drivve shaft.would i have to replace the front half of the shaft or go to a one piece?
Old 07-19-2010, 07:33 PM   #5
raycow
Re: 3 speed swap
You can go either way. My personal preference is for the one piece shaft because they are usually less trouble than a two piece. That's what I did on my truck when I replaced a 4 speed with a 5 speed.
However, replacing just the front section will be less work and probably less money if you can bolt in a stock shaft.
Ray
Old 07-19-2010, 07:52 PM   #6
keenan
keenan's Avatar
Re: 3 speed swap
where do you guys find all your drive shafts??
keenan is offline   Reply With Quote
Old 07-20-2010, 01:24 AM   #7
raycow
Re: 3 speed swap
At my friendly local salvage yard, armed with a tape measure. About 90% of the time I can find one that is close enough, needing no more work than swapping the yoke. For the other 10% I buy one that is too long and have it shortened at a driveshaft shop.
Ray
Old 07-19-2010, 09:37 PM   #8
khp71
Re: 3 speed swap
thanks ray. your info has been very helpful. ken
Old 07-20-2010, 01:28 AM   #9
BlackTopMotors
Re: 3 speed swap
Man that is good to know!
BlackTopMotors is offline   Reply With Quote
