Old 07-26-2010, 05:24 AM   #1
Wilson_
Wilson_'s Avatar
temp gauge/ overflow issue
Here is the deal, I work swing shift and go to work around 230pm and leave work at midnight.
On the way to work truck runs fine temp gauge (auto meter sport comp) stays at 180.
on the way home the truck runs fine but about 5-10 mins into the 20 min drive home the gauge pegs at 250 very fast, then drops down to 200 then a little slower pegs again then drops to 180 for the rest of the way home. I do loose coolant about a 1/4 of a gallon or so that spills out.
The probe for the temp gauge is in-between the 6 and 8 cly in the head. Should I move it to the front of the intake mani?
Here is what I have tried.
New thermostat and housing. ( the old one was pointing straight up and was off of a tbi motor)
New 16psi Radiator cap. Truck has a 87 Trans am Radiator in it. should it be higher than that??
I tried burping the system with the front of the truck pointed uphill with the rad cap off and running.
Also the truck has no heater and all the holes have been plugged
Any ideas??
Northern California Group
Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby
Wilson_ is offline   Reply With Quote
Old 07-26-2010, 06:45 AM   #2
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: temp gauge/ overflow issue
I had an issue simular to that it would run fine in normal stop n go traffic and in short distinces then temp would climb up on longer drives or up hill. But then go down to normal when I slow down for traffic or come to a complete stop. Had it check and my Radiator was plugged. Do you hit traffic on your way to work, Then on the way home just drive higway speed with no traffic maybe it could be that? It is weird though hope you get it fixed soon
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 07-26-2010, 07:26 AM   #3
cdowns
cdowns's Avatar
what type of fan setup are you running??
has this system been run without problems for a longer period of time?
if it's a junkyard radiator was it ever cleaned and tested prior to use?
Old 07-26-2010, 09:51 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Maybe going downhill to work and uphill back?
Seriously, drain all the fluid and refill with clean 50% water and 50% anti freeze or even 60% water 40% coolant. Then install an overflow tube.
You can make you a cheap one out of pvc hot water tubing (I used black from Lowes) Cap it at both ends and glue just the bottom one on. The top should fit snug but can be removed if you need to. Drill a hole just large enough to insert the radiator overflow hose in it almost to the bottom.
Place it in any convenient place and use nylon ties or large clamps to secure it. In my 68 it fits betwen grill and radiator support.
Solved my overheating problems and kept me from losing coolant. I've had it for about 2 years without any problems even in this Texas heat...
68gmsee is offline   Reply With Quote
Old 07-27-2010, 03:29 AM   #5
Wilson_
Wilson_'s Avatar
Around here the traffic on the free way is about the same at those times well there are less cars at midnight. but I go the same speeds.
Stock fan set up, The radiator came out of a running trans am that was wrecked (sideswiped) it was not cleaned or tested because of above.
I do need a overflow tank asap. Does anyone have a pic of a stock set up in a 67? I have all the parts I just cant remember how it mounts.
I will try and get a video tonight
Old 07-27-2010, 05:19 AM   #6
cdowns
cdowns's Avatar
they did not come with overflo tanks in 67
do you have a fan shroud to move air effectivly thru your radiator for cooling??
with that year radiator, if it has the stock 80's radiator cap you need to have a closed system.. radiator caps for the earlier cooling systems in 67 are made to function differently
Old 07-27-2010, 04:05 PM   #7
Wilson_
Wilson_'s Avatar
Sweet. I will check this out at home depot in a few mins
Old 07-27-2010, 05:57 PM   #8
Wilson_
Wilson_'s Avatar
I got a new cap, It looks pretty much the same as the other one but we will see how it works.
I will let you guys know tonight.
Old 07-27-2010, 08:06 PM   #9
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
You can make yourself a pretty nice "factory" looking setup with an extra washer bottle and bracket:
As long as you have the tube that attaches to the underside of the cap, it will suck water back in.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 07-27-2010, 11:47 PM   #10
tim21391
tim21391's Avatar
could it have air pockets in the radiator? thats what happened in my eclipse
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 07-28-2010, 10:40 AM   #11
pat 70/71
pat 70/71's Avatar
as stated earlier I would put a shroud on it /clean out the rad/ get the proper cap/overflow bottle and be done with it. (the only time my truck got hot it didn't have a shroud) so I learned from this and will never run without it again best of luck. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 07-28-2010, 07:55 PM   #12
68K30
Make sure that neither of the hoses is sucking shut, soft hose or no internal spring. Recently had this happen on a 70 440 Cuda, only ran hot on the highway.
68K30 is offline   Reply With Quote
