New Member
Officially a 1 ton
Spent this past weekend swapping in a Dana 60 and 14 bolt along with a 6" lift. I spent this past winter accumulating all the parts and going through everything. I picked up the Dana 60 and 14 bolt off of craigslist for $775 and then rebuilt the kingpins, and put in all new bearings and brakes all around. The front lift consists of 6" Skyjacker springs I bought from a member here and Offroad Design heavy duty shackles. The rear lift is an Offroad Design shackle flip, 56" springs out of a 3/4 ton pickup with a zero rate block, and 5" shackles from DIY4X. I also used new greasable polyurethane bushings on everything. The shocks are bilstein 5150's. I'll get more pictures as I get more time to button everything up. The tires are 36 x 12.50 x 16.5 Swampers and the diffs have 4:10 gears.
![]() Join Date: Nov 2009
Re: Officially a 1 ton
Nice transformation!!
Looks great! How does it drive (compared to stock) ?
Dustin '97 Dodge Ram (daily driver) '71 Blazer (supposed to be a toy... insists on being a project) '85 Monte Carlo SS (project) |
New Member
Here's some progress shots over the last few years. It's really dirty in the current shot.
Dude,that is awesome! Looks great, I am so trying to play catch up! More pic's of your spring-shock setup please!
What?
Awesome!
I'd love to score those axles myself to update my stuff. Love the 8 luggers!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
New Member
Haven't driven it yet. I had to pull the gas tank to install the shackle flip and I ran out of time and didn't get it back in or the new brake lines installed and blead. I still need another day or two to finish everything up.
Master Procrastinator
Sweet, looks great, no lifted truck should be without swampers
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
Hell Ya! Looks great, now you need a 454 for the BBC1Ton Club
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Big Block
You may need a engine up grade to a big block to move all that extra beef. Blazer is looking GOOD!!!
New Member
Dropped this in last summer. Pretty strong 383 stroker. We'll see how it goes.
Where'd ya get the fuel pressure regulator?
New Member
It's just a fuel pressure gauge built into the dual inlet. It's a Summit item.
Try this: http://www.summitracing.com/parts/SUM-G3120-1/?rtype=10 |
Thanks for the info
what are you going to do with your other axles
#15 |
6>8 Plugless........
![]() Join Date: Sep 2007
That looks killer! Very nice!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#16 |
very nice! perfect height, job well done. nice price on the axles
#17 |
New Member
I guess that was one positive for me about a crappy economy. The guy had them on craigslist for $1100. I offered $800, he said $850, I told him I would be there within a week since I had to drive a few hours to get them, he called the next day and said if I could get there within 2 days they were mine for $775. I left the next morning. It may be overkill but I figure it was cheaper than regearing the 1/2 ton stuff.
#18 | |
Didn't know ya had the stroker in it...must of missed that in your threads someplace. Now ya have the perfect truck! like the color too ![]()
#19 |
VERY NICE!!!!
I'm in the accumulating parts stage (already have the D60/14 & TSLs) and going with the exact same set-up you've acccomplished...including 6" lift and 383....You've inspired me to keep saving my $$$.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#20 |
awesome blazer
cucharitas customs |
#21 |
How much lift, what size tires?
#22 |
New Member
#23 |
#24 |
New Member
Got a little more done yesterday. Rear brakes are all done and replaced all the rotten rubber hoses on the gas tank vent lines. It sure is easy to work on everything back there with the gas tank out. Ordered a new rear cv driveshaft from Tom Woods today. Should be here Friday. Surprisingly the front driveshaft will work, the Dana 60 must have a longer snout than the 44. Plan is to get it running this weekend and then take it in for new exhaust on Monday.
#25 |
Wow, that is a thing of beauty!! Nice detail work. Some day when I get rich....
