Old 07-27-2010, 09:17 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Airbags
What brand and model of airbags are you guys running if you have them
Laid_Out_50 is offline   Reply With Quote
Old 07-28-2010, 07:40 PM   #2
kdog3121
Re: Airbags
just bought a kit from *****************... went with the re6 and re7's from slam specialties, heard good things about their ride and quality
kdog3121 is offline   Reply With Quote
Old 07-29-2010, 12:11 AM   #3
reds65ss
Re: Airbags
slam specialties are pretty good bags, they have a nice ride at a wide range of pressure. they also have built in bump stops so when you are riding real low you don't have that harsh bottoming out that you get with some other bags. conitech's are a close runner up to the slams. the way the coni's are put together seems so make them last along time even when you abuse the hell out of them.
reds65ss is offline   Reply With Quote
Old 07-29-2010, 01:58 AM   #4
Laid_Out_50
Re: Airbags
Ya my suspension guy wants me to buy this $1900 kit from Universal Air and to have 8-9 switches when I only need 3 switches. What about Firestone bags?
Old 07-29-2010, 03:12 AM   #5
Tchia65
Re: Airbags
I'm waiting for my ifs kit, and 4 link from No limit. They use Firestone. I'll let you know how it turns out if I can find an affordable air management kit.
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
Old 07-30-2010, 11:35 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Airbags
The optimum is 5 switches. It's nice to have one for each corner so you have the ability to compensate for various loads, fuel, etc. It's also nice to have one that dumps the system.
Firestone bags are the standard of the industry. You can't go wrong with them.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-30-2010, 03:22 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
Re: Airbags
Slam Specialties, RE-7 front, RE-8 rear.
chevyrestoguy is offline   Reply With Quote
Old 07-29-2010, 10:47 AM   #8
Scottshotrods
Re: Airbags
We use slam speciality bags with our ifs kits we make and sell.We have had great
results with there bags.We have several dozens in stock if any of you guys need some.
Justin
www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 07-29-2010, 07:38 PM   #9
reds65ss
Re: Airbags
i would go with slams, firestones are good bags though. i think your can put together a system for less than 1900, what all does it come with? seems like there is a lot of knowledge here to help you put together a nice system to suit your needs.
Old 07-29-2010, 07:39 PM   #10
reds65ss
Re: Airbags
is this the kit?
Item Description
This is a Universal Fitting system designed for a 4 seperate coil/torsion, leaf suspension. The bags are 5.875" Diameter, with a 2" collapsed to 8.5" extended front bag and 2" collapsed to 11" extended rear bag. We will build the brackets out of our database, or to your specifications.
Track tested, Show Stopper Air Suspension Kit! Dont settle for less! Check out our Gallery.
F.B.S.S. SYSTEM INCLUDE
2 VIAIR 480C, 200 PSI, 100% DUTY CYCLE
1 200 PSI PRESSURE SWITCH
1 SWITCH BOX (Hand Held 9 Switch)
8 "Blow Proof" 1/2" AIR SOLENOID VALVE
2 UNIVERSAL AIR SUSPENSION DOUBLE PLAY 11"
2 UNIVERSAL AIR SUSPENSION AIR HOUSE 8.5"
1 D.O.T. APPROVED FITTING & HOSES FOR F.B.S.S
1 CHROME ALUMINUM AIR TANK
1 SET OF BRACKET KIT
1 HEAVY DUTY SOLENOID
1 BOLT PACK
US PATENT US 6457702
Old 07-29-2010, 08:00 PM   #11
Laid_Out_50
Re: Airbags
Originally Posted by reds65ss View Post
is this the kit?
Item Description
1 BOLT PACK
Yes that is the one.
Which bags should I go with RE6 or RE7
Old 07-30-2010, 12:19 AM   #12
reds65ss
Re: Airbags
well i'm guessing you are bagging a 50 based on your screen name? it all depends on what front suspension you go with. you might not be able to fit the 7's. what are you doing in the rear?
Old 07-30-2010, 12:42 AM   #13
Laid_Out_50
Re: Airbags
I am running a MII front end with a triangulated 4 link in the rear with a notch
Old 07-30-2010, 10:31 AM   #14
junkman1jmc
junkman1jmc's Avatar
Re: Airbags
im runnin airlift on my 48 with a s10 frame with no problems in 4 years. thinkin about swapin out with some slams
junkman1jmc is offline   Reply With Quote
Old 07-30-2010, 07:50 PM   #15
kdog3121
Re: Airbags
i agree with chevyresto, when it comes to bags, bigger is better and will also give a better ride quality. i'd run the biggest that will fit.
i have a 6 link in the rear and due to space/clearance req's, i can only run 6's in the rear.
in the front, i have a '94 s10 front clip with oem control arms - you need to cut some of the cup of the frame to get the 7's to fit, but it's not too bad and the ride will be much better.
just my 2cents
Old 07-31-2010, 10:54 PM   #16
Kid
Kid's Avatar
Re: Airbags
I have never tried the convoluted bags in the rear, so I cant speak of their ride quality, (although I do question the ride quality due to their stiffness & limited travel) I used firestone rolling sleeve bags in the rear with triangulated 4 link & love the ride, in town & on the hiway. If / when I need to replace the front Firestone convoluted bags, I would like to try the "Slams", but have no complaints with the Firestones.
Kid is offline   Reply With Quote
