Old 07-28-2010, 03:29 AM   #1
Tchia65
58 Fleetside
My name is TJ, first time poster and to make a long story short; I was given a 1958 Fleetside in High School but my Father wouldn't let me bring it home and I've wanted one ever since. Recently got a 1/2 ton short box and I'm in the middle of a LS1, 700R4 swap and chassis upgrade. Waiting on my No Limit kit to come in. Wondering if anyone has any pictures of their task force with the No limit kit installed? Also, for those with rack and pinion, is anyone running an OEM steering column? I was thinking of putting in a Caddy tilt, telescoping column. Last question, is anyone running a Mustang 5 lug 8.8, and how does it fit?
Thanks, TJ Higgins
Tchia65 is offline   Reply With Quote
Old 07-28-2010, 08:06 AM   #2
blackdiesel
blackdiesel's Avatar
Re: Finally got a 58 Fleetside, New to this site.
Welcome, we like pix. Check out the build threads there are a lot of us that has all different kinds of IFS set ups. I have a ls and a 4l60e in my truck and love it. I have never seen a OEM column hooked up to a rack, don't think it can be done with out a lot of mods. OrrieG has a caddy column in his truck. I myself and a bunch more run the 8.8 and it works real nice. The explorer model is the good fit. With your overdrive tranny the 3:73 gears posi track and rear disc brakes are a nice upgrade for around 200 bucks, can't beat that.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 07-28-2010, 12:26 PM   #3
Kabwe
Certified Car Nut
Kabwe's Avatar
Welcome to the site and please post pics.
Kabwe is offline   Reply With Quote
Old 07-28-2010, 06:46 PM   #4
Tchia65
Here she is. Got the motor ready sitting on a pallet, frame is now bare waiting for my No Limit kit (hopefully Friday). Need to make a decision about the firewall, Patch or replace? For the record I did not do that...
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 07-28-2010, 11:41 PM   #5
MrSinister
MrSinister's Avatar
cool project love those fleetsides and
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 07-29-2010, 07:42 AM   #6
blackdiesel
Is that a 5.3 or a 6.0? I really like the 4l60e over the 700r4, I know that you have to have a computer to run it and you can't use the stock speedo. I've got both in old cars and the 4l60 out proforms it bad. JMO You can check out my thread project 2 wd http://67-72chevytrucks.com/vboard/s...d.php?t=368287 I put a speed wat IFS under mine.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 07-29-2010, 04:42 PM   #7
Tchia65
Black Diesel. I wanted a 4l80e but this truck is going to be my daily driver and budget is a primary concern. engine is a 5.3, planning on swapping cams and intake after I get it on the road. I'm scrambling to find a column, air management kit and a rearend since I blew all my money on the chassis. What year 8.8 are you running, and what is your rim offset? I have a nice set of 15x10 rally’s that I want to run, but they have a real sallow offset (4.5). Still need to make a frame tank, smooth the firewall and install the chassis. Saw your Dodge in your 1 piece window video, nice.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 07-31-2010, 01:06 AM   #8
Tchia65
Got nine boxes from UPS today, now I just need time.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 08-01-2010, 12:43 AM   #9
poncho_villa
poncho_villa's Avatar
Welcome to the site. It sounds like you've got a really nice project happening. Keep that camera going, we want to see what you do with the contents of them nine boxes.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 08-04-2010, 12:42 AM   #10
Tchia65
Finally got the cross member out (not fun without a torch) and the frame shaped up. Notched the frame for the No Limit cross member, thought I could save the factory E-brake mount (couldn't). Drilled out the firewall spot welds getting ready for my new one on Monday. Doing the work at the auto hobby shop on base, they don't have 220v. Need to find a generator so I can get this welded up.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 08-04-2010, 12:46 AM   #11
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I've always liked the late 50's trucks. Nice project! Should be fun when its done!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-05-2010, 11:54 AM   #12
dewey777
dewey777's Avatar
welcome fellow short fleet!
1959 Chev Apache 3100 Short Fleet Big Window
dewey777 is offline   Reply With Quote
Old 08-08-2010, 02:55 AM   #13
Tchia65
Successful day, today was half price day at the wreaking yard. Got a 3.73 limited slip with disc brakes, aluminum drive shaft, and a telescoping Cadillac steering column for $160
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 08-08-2010, 08:32 AM   #14
blackdiesel
Nice score there. I got the aluminum shaft out of the explorer all so. All I had to do is get a u-joint that the cross was big on one side than the other, to put it to my chevy slip yoke and it was the prefect length.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 08-08-2010, 02:07 PM   #15
Tchia65
Sweet, thats what I like to hear. I figured worse case senerio I would put the explorer end on my shaft since I can't find the spicer adapter. Direct sheetmetal is right down the street so I'm picking up my firewall tomorrow. Hopefully I can get this 220v thing figured out so I can start welding. Started tearing apart that Caddy column. Thought I could weld up the ignition hole with some fill rod, but turns out the column in magnesium so not sure what I'm going to do now.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 08-08-2010, 05:01 PM   #16
blackdiesel
I've seen guys cut the switch off and fill it with J-B weld and worked great.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 08-10-2010, 02:21 AM   #17
Tchia65
Picked up my Firewall today. Got it rough fitted. Really wanted to start tacking it in, but was you can see from the pictures the previous owner was not an electrician. Gonna clean up that mess first. Still need to make the bottom patch panels to fix more of the prior owners mistakes.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 08-30-2010, 11:20 PM   #18
Tchia65
Progress, finally. Had to borrow a generator to power my welder.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 08-31-2010, 12:09 AM   #19
Kim57
Kim57's Avatar
That looks preetty good.
Kim
Kim57 is offline   Reply With Quote
Old 08-31-2010, 01:33 PM   #20
hotrodrookie
hotrodrookie's Avatar
Welcome to the site. You have the looks of a good build. Im also doing the 5.3 and 8.8 explorer rear in my 59. What are your plans for rear suspension? No limit fat bar?
hotrodrookie is offline   Reply With Quote
Old 09-01-2010, 12:53 AM   #21
Tchia65
I checked out your build last night, I'm a little jealous. I have always wanted a 58 Fleet and this one is replacing my 72 Malibu Wagon as my daily driver. I have given myself a three month deadline to get the truck on the road so I threw a bunch of money at it and bought the full No Limit airbag chassis package. I'm a month into it and behind schedule...
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 09-15-2010, 01:11 AM   #22
Tchia65
Progress. mock up the motor this weekend.
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Old 09-15-2010, 06:07 AM   #23
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work! Good luck with the time line! Keep the updates coming. In the link to Blindmans build he's got the No-Limit IFS with coilovers and Fat-Bar rear.
http://67-72chevytrucks.com/vboard/s...d.php?t=377388
ChuckDriver is offline   Reply With Quote
Old 09-16-2010, 10:10 PM   #24
truckdude239
truckdude239's Avatar
Re: 58 Fleetside
thats an alsome build dude looks great
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-18-2010, 12:53 AM   #25
mexgrhd68
mexgrhd68's Avatar
Re: 58 Fleetside
looking good, keep it up!!!
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
