Pics of where the best place to install a temp gauge on a 350?
Is there a more accurate place to put the prob for a temp gauge on sb 350?
Just cause my Hood is up every weekend doesn't mean its broke down!! ![]() ![]() |
Between Trucks...
Re: Pics of where the best place to install a temp gauge on a 350?
I have mine in the driver's side head.
Beat it to fit, Paint it to match... ![]() |
Junior Member
Mine is in the driver's side head. Also the '92 454 has it in the driver's side head.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Yep, driver side head.
Mines in the intake next to the thermo housing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
needs more $$$
What's the difference in temperature readings between these 2 areas?
(not meaning to hijack the thread)
1970 2wd Blazer |
#7 | ||
"I ain't nobody, dork."
Drivers side head is where the stock location is. That's where mine is.
![]() Gary
*** That's interesting ***
+1 on the driver's side head for a normal flow Chevy V8 engine. On a reverse flow engine (like the 90s LT1), it went on the passenger side head.
You can also put it in the water pump or intake bung as others suggested. You might get a more consistent reading there since the heads do heat soak (and sometimes cars with EFI use two different sensors for this reason). If you are using EFI, and need a probe for the computer, I'd say use the WP or intake. If you are hooking up a gauge, I'd say put it in the head. A head will heat up very fast if there is a cooling issue and it will also show up on the gauge faster to warn you.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
i have a gen one 350 with headers, the prob is on the pass side of the truck and i dont think the reading is accurate...is it more accurate to have on driver side or water pump bung?
#12 | |
"THE GREEN GOBLIN"
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 07-29-2010 at 02:29 AM. |
#13 | |
Reverse flow is only applicable to the '92-97 Corvette (and '94-96 B/D-Body) LT1 engine. On these motors, the WP was driven from the cam, and it pushed water through the heads first. It's actually a neat system. There are lots of details online about this, one link being: http://sstilletto.tripod.com/sstilletto/id11.html Though now that I think about it, I'm not sure it matters which side head you put the temp sensor on.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 07-29-2010 at 02:17 PM. |
#14 | |
"THE GREEN GOBLIN"
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#15 |
![]() Join Date: Jun 2008
If my heads not have the ports to install the temp guage and now I am going to use the port on the intake, next 2 the thermostate for an eletric fan where can I put he probe for mecahnical temp guage. Or since the eletric fan has two probes can i split one to hook up a eletric temp guage.
#16 |
its all about the +6 inches
in the head, left or right, is the best place to put it.
If hooking a fan controller, in the rad is the best place for it. |
#17 |
Truck and auto performance nut
if worried about engine temps....you could also add an oil temp gauge to get a better view into your motors internal temp. Mine doesn't have one now, but will one day when I finish the interior.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#18 |
my stock gauge sender is in the drivers head. i just added a mech. gauge (had it already)in the thermo housing. it gives me a nice indication of the status of the cooling process or the temp. of the water coming out of the radiator. after i have it there a while i'll move it to the more standard location the intake mani. right now it seems that the stock gauge reads right on.
#19 |
I had mine in drivers side head and moved it to the passenger side head to allow for putting a second sending unit for my dual electric fans. When I placed temp gauge in passenger side head the temp reading was at least 30 degrees hotter compared to the reading when gauge was in drivers side head. Everything was exactly the same except temp reading. I am not positive but I am hoping the difference was due to the fact as the water circulates through engine and heads it heats up so when it gets to the gauge port on drivers side head it has soaked up a bunch of heat causing the difference in temp reading between the to ports. Can someone please tell me if this is correct or do I have another problem all together.
