Old 07-29-2010, 11:51 AM   #1
WellBilt Kustoms
converting to 5 lug, problems with rear and driveshaft
I have a 63 Longbed fleetside, has a 350 with a powerglide behind it. I'm in the process of converting the truck over to a 5 lug, all parts are coming off of a 87 suburban. The rear end is a 10-bolt. The old rear in my truck was a Eaton 8 lug.
I have the new 10 bolt set on the trailing arms, but the problem i'm having is the driveshaft. When I put in the yoke into the tranny, its completely pushed all the way in just to get the rear U-joint to bolt up, and thats even hard to do. This is with the suspension hanging down also. So there's no way at ride height it will work. I'm not sure if the previous owner swapped in a 3/4 or 1 ton driveshaft when he swapped in the Eaton 8 lug rear. The driveshaft itself looks fairly large in diameter.
Can someone measure there driveshaft for me? Or does anyone know what the measurements should be for a stock 1/2 ton driveshaft for a longbed truck?
I'm thinking about either cutting an inch and a half out of mine, welding it back up, then going to get it re-balanced. Or...getting another driveshaft off of something else that will be the right length.
WellBilt Kustoms is offline   Reply With Quote
Old 07-29-2010, 12:02 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: converting to 5 lug, problems with rear and driveshaft
It would be best to put the truck at ride height and with all the weight on the tires...then, measure for your driveshaft length. I use a chart similar to this one when measuring for driveshafts in my projects: http://markwilliams.com/driveshaftOrdering.aspx
This way you'll know for sure what the measurement will be for your application - then you can shorten your driveshaft or have a new one made at the precise length for your truck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-29-2010, 12:11 PM   #3
michael bustamante
michael bustamante's Avatar
If you need another correct 2 piece drive line, let me know. (pm) I pulled one out of a 62 3/4 ton. v8 with a 3 speed and a granny gear so you would still have to swap slip yokes
1967custom
michael bustamante is offline   Reply With Quote
Old 07-29-2010, 12:15 PM   #4
WellBilt Kustoms
driveshaft I have now is a one piece. My truck doesn't have a carrier bearing
Old 07-29-2010, 01:30 PM   #5
WellBilt Kustoms
just got done measuring everything. Can someone post up measurements of there 1/2 ton one piece driveshaft for there longbed pickup? I just want to compare and see how much larger this one is. I'm thinking its out of a different truck thats a 3/4 or 1 ton.
From center of u-Joint to center of U-Joint, length is: 67"
Length of Yoke that goes into tranny: 3.75"
Total length of driveshaft (End of yoke to end of U-Joint) : 73.5"
Diameter of Driveshaft is: 11.25"
Old 07-29-2010, 01:50 PM   #6
vin63
vin63's Avatar
Most of the long bed trucks had a two-piece shaft with a carrier bearing mounted on the trailing arm mount crossmember. I believe you measured the circumference of the shaft, which translates to a 3.5" diameter. Consult with a driveshaft maker if you want to stick with a one-piece steel shaft because a 3.5" dia. shaft that is 67" may present some critical speed issues in your application. If you need a relatively local contact, I've used J. E. Reel before:
J. E. Reel Driveline
448 S. Reservoir
Pomona, CA 91766
(909) 629-9002
Old 07-29-2010, 02:02 PM   #7
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
!!!, you do mean circumference, right?
1. you mean you swapped rear ends and now the driveshaft is too long? the only thing that would cause this(other than not locating it properly on the trailing arms) is if the new carrier is longer (what I mean is the pinion u-joint is further forward), if so measure the difference between the new and the old, that should be the distance that you need to shorten
2. I didn't think our trucks came with single piece shafts originally but maybe.
Larry
fleetsidelarry is offline   Reply With Quote
Old 07-29-2010, 02:21 PM   #8
WellBilt Kustoms
1. you mean you swapped rear ends and now the driveshaft is too long? the only thing that would cause this(other than not locating it properly on the trailing arms) is if the new carrier is longer, if so measure the difference between the new and the old, that should be the distance that you need to shorten
Correct. I appologize for that. Its a 3.5" diameter driveshaft, not 11.25". (That would be just crazy huge!)
Do you think I should get a carrier bearing and carrier bearing bracket and find a 2-piece driveshaft for it? If I can get away with just cutting mine down and getting it rebalanced, or finding another one piece that will fit, i'd rather do that. alot easier and time effective, but if it is going to create problems such as vibration at higher speeds, i'd rather just go with a 2-piece.
Thanks for the replies guys!
