07-29-2010, 09:17 PM | #1 |
What is this crossmember..??
This crossmember is located right below the firewall. I cant see it being a trans x member? I believe the th400 are located further back near the tailshaft. We are going to run a 350 &th400. Does it have to come out? Thanks guys!
07-29-2010, 09:30 PM | #2 |
Hollister Road Co.
Re: What is this crossmember..??
Bellhousing mount for a standard trans. It would be in the way for a TH trans
07-29-2010, 09:35 PM | #3 |
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
07-29-2010, 09:43 PM | #4 |
Thanks for the quick responses guys. This crossmember is on its way out. Should the frame have factory holes farther back for the th crossmember?
07-29-2010, 09:48 PM | #5 |
Yes
Fuzzy |
07-29-2010, 09:49 PM | #6 |
yes it does have factory holes for the TH crossmember.
07-29-2010, 10:01 PM | #7 |
ok, another one for you guys. I have these two crossmembers. The black one has a wider mouth to it and doesnt have holes drilled in the sides like the other. Are they both th crossmembers. They came with the truck,so Im not sure. Thanks again!!
07-30-2010, 09:09 AM | #8 |
will these work for the th400?
07-29-2010, 11:11 PM | #9 |
6>8 Plugless........
I think the wider one could maybe a C20 and not a C10. But I'm not for sure on that.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-29-2010, 11:25 PM | #10 |
dieselwrencher, do you have any pics of your cummins conversion. I really want to do another truck with a 12v.
07-29-2010, 11:36 PM | #11 |
Here is the thread of my Longhorn, which isn't done yet. The diesel conversion starts on Pg.3.
http://www.67-72chevytrucks.com/vboa...light=longhorn
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 07-29-2010 at 11:56 PM. |
07-29-2010, 11:46 PM | #12 |
link didnt show.....
07-29-2010, 11:56 PM | #13 |
It should now.
