Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-31-2010, 12:03 PM   #1
WI_Jeff
Newer truck feul problems
I know you guys deal with older Chev trucks. I'm good with them myself. New stuff drives me crazy! I have a 1989 Chev S-10 with the model 220 throttle body. Ran great until 2 days ago. Then she would not start. Primed the throttle body and it started and ran great. I replaced in tank fuel pump. Same thing. I have to prime it to start it then it runs great. Color me stupid, but I can't think what else it could be. Not at all up to date with fuel injection of any type. Any ideas would be greatly appreciated.
WI_Jeff is offline   Reply With Quote
Old 07-31-2010, 04:34 PM   #2
kevmic28
kevmic28's Avatar
Re: Newer truck feul problems
Clogeed inline fuel filter maybe???
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 08-01-2010, 05:32 PM   #3
bwood
bwood's Avatar
Make sure you hear the fuel pump priming when you turn the key to run but it sounds like a ignition module issue. It is located under the rotor in the distributor. The module has a start and a run mode and in the start mode, it is looking for th e starting rpms (under 400). Once it sees the low rpm cranking, it gives a reference pulse to the ECM to fire the injectors. Once the injectors start firing and the rpms climb, it goes into the running mode and starts to control the injector firing rate. When you prime it, it spins up enough to get into the running mode. You can have the module tested at the parts stores for free, just make sure they test it a bunch (I usually shoot for a dozen times in a row). The module heats up as its operating and can pass when cool and fail when hot. When you remove or replace the module, you have to make sure that the white heat sinc compound/grease is in between the module and the dist base or it will fail. The heat generated in the module is disappated through the distributor body, no heat sinc compound, module will overheat. Make sure its heat sinc compound (should be white) not dielectric grease.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 08-02-2010, 11:47 AM   #4
WI_Jeff
Thumbs up Re: Newer truck feul problems
Thanks a bunch!!!! What happened to gas and spark and it runs?
fuel
