Ball Joint seals?
Anyone know where I could pick up some ball joint rubber seals without buying the ball joints? I know several people here have separated spindles and put them back together. I always seem to tear mine.
Re: Ball Joint seals?
Energy Suspensions has the poly ones you can buy. check Summit or Jegs
Great thought thanks
But Summit online only lists 1988 and newer ![]() Jegs is not coming up for me ![]() Last edited by 1LowToy; 07-31-2010 at 08:53 PM. |
Master Procrastinator
eBay had them the other day for tie rod ends, don't see why they wouldm't have ball joint caps
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
Still no luck
Jegs website won't come up for me Summiy no Ebay no Anyone?? |
At the body shop.
I think the 88's use the same joint
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 08-01-2010 at 03:33 PM. |
check Energy Suspensions website for ball joint boots
The help section at the auto parts store should have them. Stop using the seperator and you wont rip the boots. If you just hit the spindle itself where the stud goes through with a 3lb or so hammer they will pop right apart. No need to endlessly beat on that seperator and tear up the ball joint.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
I found that the upper ball joints are the same as the 88 model and are available.
As I recall I separated the upper ball joint with my tierod end separator. The lower ball joint was the real PIA and I did try the BFH trick although I was not able to break them loose, hense the air tools and ball joint separator. This time when I go to taking it appart I'm going to try a mini hydraulic jack and see if it has enough power to do the trick. |
Just hit it harder. loosen the nut just enough to let the spring pop the ball joint loose but you need it to be tight enough that it doesnt come apart. If all else fails get a bigger hammer
