Old 08-02-2010, 11:04 PM   #1
snacob14
gearing and axle questions
I'm running a 285 rear on a 20" wheel. I've got an 87 w/700r tranny. My rearend is currently either 2.73 or 3.08, I haven't gotten under it a checked yet. My question is what are you guys running for gears on this size tire. Overdrive is kinda useless unless I'm doing 80. I'm thinking 4.10's would be good, but I don't want it to be screaming down the highway. I was thinking it would cost quite a bit to do the gears, even if I did it myself I'd be 300 deep in parts. I may just look for a rear already geared or even a 9inch if the wms width was the same. What are you thoughts.
snacob14 is offline   Reply With Quote
Old 08-02-2010, 11:11 PM   #2
f.monroe
f.monroe's Avatar
Re: gearing and axle questions
Exactly what size tire ? 285/??/20.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 08-03-2010, 08:28 PM   #3
snacob14
285/50/20
Old 08-03-2010, 08:55 PM   #4
85burb
85burb's Avatar
If that is about 33 inch tire 4;10 will be good. I have a 85 4X4 burb with 285/75/16 (33 or so). Got a 700R4 and 4:10s they a little low for in town but i love the set up. Hits overdrive with converter lock up at about 45-55 if i baby it. My week old 350 does not have trouble keeping up. It will also do over 100 MPH on high way. What axle do you have. If you do have 3.08 you will have to change your carrier i beleve.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 08-03-2010, 09:00 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I WOULDNT GO ANY LOWER THAN 3.73 GEARS. SEEMS TO BE THE BEST ALL AROUND GEAR. SORRY, MY CAPS LOCK APPEARS TO BE STUCK ON
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-03-2010, 10:01 PM   #6
DubDubU
DubDubU's Avatar
My rear tires are 28.5 in. tall. With the 700r4 and 3.73 gears I'm running 65 mph just under 2000 rpm. The tire calculator I use says your tires are 31.2 inches tall. At 2000 rpm you could be cruisin at 70.
'79' shortbed
DubDubU is offline   Reply With Quote
Old 08-03-2010, 11:11 PM   #7
snacob14
Dude! Where are you at in STL. I live just south in Festus. I saw at one time there was a truck show in Arnold Park a while ago.
Old 08-03-2010, 11:25 PM   #8
DubDubU
DubDubU's Avatar
I've been at that show for the last 3 or 4 years. This year its on August 21st, at 11 am till 3 pm. Same place. Bring your truck up and have a good time. I live in Brentwood, near 170 and 40.
'79' shortbed
