Old 08-03-2010, 02:15 PM   #1
hobsiscool
need your expert opinion
Ok so my new fuel tank and sending unit finally came in, and it turns out, the sending unit appears to either be the wrong one (it's labeled correctly on the packaging) or it's for the passenger side....on the OEM unit, the 2 ports point inward toward the frame, with this tank, once installed, the ports point outward.
My question is that is it going to cause any problems down the road if I just make my fuel line loop a bit to make the turn? I don't want to cause kinks or anything down the road, but I don't want to go through the hassle of doing the whole return thing (got them from RockAuto)
Let me know what y'all think...my thinking is that as long as it isn't going to kink it should be fine, but i'm sure someone out there has had the same issue.
hobsiscool is offline   Reply With Quote
Old 08-03-2010, 02:40 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: need your expert opinion
I think it would be fine also
ont_guy_38 is offline   Reply With Quote
Old 08-03-2010, 03:12 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
It will likely be ok but I would just get the right unit if it was me.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-03-2010, 03:26 PM   #4
hobsiscool
if it didn't involve shipping it back to Indiana, I'd probably get the right unit as well...but if it's not going to cause any issues, then i'm just going to run it like it is.
Old 08-03-2010, 04:39 PM   #5
hobsiscool
I ordered Spectra Premium unit FG05H, but it appears that part #FG05E (listed as p/s) may be what I need. Can anyone confirm this? I've emailed rockauto about the issue to see what their response is. I'd hate to return the one I have only to find out that the one listed for p/s is also wrong.
Old 08-03-2010, 08:10 PM   #6
hobsiscool
correction...I did a little more sleuthing, they actually sent me part #FG05E, which is indeed for the passenger side...I will be returning this for my correct part.
*edit:
Top notch customer service on RockAuto's part...I called them, verified my problem, emailed me a pre-paid fedex slip and said once they scan it into their system, my new part will be on the way...hopefully I can get this thing installed pretty soon.
