08-05-2010, 06:35 PM | #1 |
New engine help
alright guys heres my issue.
i have a 65 chevy with a beat up 350. its basicly a parts engine witch i figured out when i took it appart to clean it. the block is from a 70 car, heads are 76-85 truck, i think. intake is a 68 truck. 2 barrel rochester year vehicle ??? who knows. i tried to make it work but now the valve stems are bad and rocker nuts keep loosening. block is bored .40. im tired of messin with it. srry for the rrrrrrrant point is i want to drive the heck out of it but right when it seems to be good something new happens. what is a good crate engine that i can drop in and go for a good price. i want it to be a DD and not looking for anything fancy. i have the original powerglide still attached. thanks in advance this site rocks |
08-05-2010, 07:11 PM | #2 |
Re: New engine help
The 290hp GM 350 is a fantastic engine and would deliver plenty of power without breaking the bank.
Have you checked the cylinder walls and measured them? If they are good why not just re-ring and bearing the short block and install a new set of aftermarket iron heads? |
08-05-2010, 09:32 PM | #3 |
Re: New engine help
thanks Blackedout,
do you have a link. im really sick of dealing with that engine so i really dont want to bother anymore. plus the crank is stripped where the harmonic balancer bolts on to. i got maybe 2 threads in |
08-05-2010, 10:17 PM | #4 | |
Re: New engine help
I got mine from summit. |
08-05-2010, 10:24 PM | #5 |
Re: New engine help
is it a long block or a complete engine carb to pan?
08-06-2010, 05:42 AM | #6 | |
Redneck Hillbilly
Re: New engine help
^+1 For an inexpensive crate engine (everything is new), this one is hard to beat. Comes with a warranty, has enought power to be fun on the street, and is still mild enough that fuel mileage and drive-ablility is more than reasonable. I know quite a few guys who have this engine for exactly what you are looking for, and love it. |
08-06-2010, 03:42 AM | #7 |
Re: New engine help
08-06-2010, 10:10 AM | #8 |
Re: New engine help
call up the dealer near you and tell them you want a crate engine and how much they can get you one for. You live in San Jose so there are many around. I got a crate engine for my 79 in Pittsburg @ Winter Chevrolet .
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-06-2010, 10:15 AM | #9 |
Re: New engine help
http://www.fhdaileycars.com/PartsOrderForm Try here. They might be expensive though. You can also look in the phone book and make some calls.
08-06-2010, 01:08 PM | #10 |
Registered Loser
Re: New engine help
You may want to check out Blueprint Engines. They have lots of different packages and are fairly inexpensive. I got thier 405 hp 383 longblock with intake manifold for on sale for $2965 (normally around $3200) before taxes. They use remanufactured blocks but everything else is brand new and they come with a 30 month warranty. Summit Racing and Jeg's both carry them.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
08-06-2010, 03:45 PM | #11 |
Re: New engine help
For a new 350 I'd check out Jeg's. They beat Summit prices too. As mentioned the 290 HP is quite an engine but you mentioned saving a few bucks. The 260 HP engine fron Jeg's sounds like the way to go..check prices and compare...btw these are new engines not rebuilt with a nice warranty.
Bob |
08-06-2010, 04:44 PM | #12 |
Re: New engine help
Thanks for all the input.
what intake and carb would work well with either the 260 hp or 290 hp engine? this way i can compare and see what my pockets can handle. i dont have a specific budget but dont want to go crazy. if it feels right i ll go for it. thanks |
08-06-2010, 05:04 PM | #13 | |
Re: New engine help
Stay away from single plane manifolds! The Edelbrock Performer RPM and a 600 Holley (#1850) work perfect. Also, if you don't already have one I highly recommend going to HEI ignition. |
08-06-2010, 09:44 PM | #14 |
Re: New engine help
would this be a good set up? im not sure what works with what.
http://www.summitracing.com/parts/NAL-10067353/ with http://www.summitracing.com/parts/CMB-03-0077/ |
08-07-2010, 01:34 AM | #15 | |
60-66 Nut
Re: New engine help
That top end kit would work, but for the slight difference in money I would go with at least the 260hp engine.....it's only $200 more for an extra 65hp.
08-07-2010, 03:25 PM | #16 |
Senior Enthusiast
Re: New engine help
I found the receipt for my engine, that's the one I have 10067353. I'm running an Edelbrock Performer RPM manifold (because I got it for free) along with a 1405 600 CFM Edelbrock carb, and stock HEI. The only engine modification is a Pete Jackson gear drive. It has somewhere around 150k on it now and still runs great. Whenever the budget allows I'll replace it with the same thing. I believe the only differences on the 290 hp version are a nodular iron crank and a different cam. Unless you're going to build it up I'm not sure that's worth another $500.
08-08-2010, 01:41 AM | #17 |
Re: New engine help
you cant beat the 3 years or 100,000 miles warranty, i have installed a half dozen of the gm crate engines in various vehicles without any problems and the confidence of a nationwide warranty covered at any dealership
08-08-2010, 05:27 AM | #18 |
Re: New engine help
Don't forget to factor in the cost of freight as well.
The Edelbrock EPS manifold is also a good choice but I cant say anything about their carbs; no experience with them. |
