Old 08-08-2010, 03:37 PM   #1
daverod
SSN 706
daverod's Avatar
airlines to front bags?
Pics of how you ran your front airlines to your bags? Doesn't seem to be a good way?
daverod is offline   Reply With Quote
Old 08-08-2010, 03:45 PM   #2
shortbed70
shortbed70's Avatar
Re: airlines to front bags?
I wen t straight down through the spring pocket and droped into the top of the bag.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-08-2010, 03:48 PM   #3
daverod
SSN 706
daverod's Avatar
So you drilled a hole? or out the crossmember? I did'nt any pics in your thread. Trucks getting there though.
Old 08-08-2010, 03:56 PM   #4
shortbed70
shortbed70's Avatar
Ill go get you a pic....
Troy
Big Red Dog build
Old 08-08-2010, 04:04 PM   #5
shortbed70
shortbed70's Avatar
Here you go.
Troy
Big Red Dog build
Old 08-09-2010, 09:46 AM   #6
daverod
SSN 706
daverod's Avatar
Originally Posted by shortbed70 View Post
Here you go.
Thanks Shortbed.
Old 08-09-2010, 01:11 AM   #7
lonestarluck
lonestarluck's Avatar
i used 90 degree fittings on the bags and ran them through the cross member to the passenger side and out through an unused hole
lonestarluck is offline   Reply With Quote
Old 08-10-2010, 12:57 PM   #8
Malibob
Malibob's Avatar
Mine run through the front crossmember with 2 holes in the rail (w/ grommets of course), 90's on tops of the bags. They are T'ed at the instruments.
I did this because I wanted F+B not FBSS and doing it at the 1/4" lines slowed the air down a bit so I didn't get crazy roll in turns. Also, if I ever need to change it (when the new crossmember is installed) then it is easier to change.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
