Lift Pics
Anybody have some pics of different lift combos? I'm thinking 2.5" with 33" tires, but I'd like to see some pics first. The alternative would be 4" lift with 33" or 35" tires. This would be going on a CCSB...
Thanks! |
Re: Lift Pics
This is a 4 inch lift with 35's.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 Last edited by Sillyoldman; 09-02-2010 at 08:32 PM. Reason: Removed dead link |
Re: Lift Pics
i personally think a crew needs 4+ because of the length.. to look appropriate.. i want 6-8 and 37's when i build one
Re: Lift Pics
This is what I just got home and I do not like the lift/tires it has. It has 8" suspension plus 3" body and 38"x15.5" Toyo M/T's. It drives like crap! This will be my driver and I need it to be practical and still look good...
I'm a little worried that 4" lift with 33" tires will look a little awkward. Thanks! Levi |
Re: Lift Pics
deepnsteep:
Do you have your caster angles worked out? Do you have a steering brace and crossover steering yet? Upgrade to a XJ steering shaft. My 6inch and 35s steered better than stock when i was done with it. Also, always use a shackle flip in back, it rides much better. Use longer 56" springs also. Last edited by blakeduren; 08-09-2010 at 07:20 PM. |
#6 | |
Re: Lift Pics
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: Lift Pics
Nevermind. I just did a little research on the crossover steering and it makes perfect sense now lol
Re: Lift Pics
Yes, even in a parking lot you can get more lock to lock turning compared to a raised steering arm correction etc. On highway bumps, your steering will not wonder as your suspension travels.
And of course, offroad is where that crossover really shines when you can actually turn all of the time. |
#9 | |
Re: Lift Pics
#10 | |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Lift Pics
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#11 | |
Re: Lift Pics
It does get a lot of looks. I happened to hit Hot August Nights just right in Reno bringing it to Wyo from California last Friday. It doesn't look as big in the pic as it does in person!!
I do not have a steering brace but am considering it. I plan on a 4" lift max and didn't really think crossover is really necessary with that amount of lift. Note taken. Does the shackle flip give a better ride than skyjacker springs even? Use stock springs for 4" lift? Thanks for the input! Levi |
Re: Lift Pics
Here is a picture of my work in progress. Have a 4 inch lift on order, as it sits in the picture it has a 3 inch lift with 33's. I photo shopped out the rust in this picture lol
built not bought
Re: Lift Pics
here is mine. 4 inch all spring rough country lift. The first pic is with 33s on 16 inch wheels, and the second is how it sits now, 35/1250-20s.
MY BUILD THREAD "project: what you doin that for?" http://67-72chevytrucks.com/vboard/s...d.php?t=382503 |
#14 | |
Re: Lift Pics
Do the steering brace! Crossover is always worth it if you drive the truck often. Shackle flip is the best way to go for flex and for ride quality. Stock springs give about a 4 inch lift. I used some 56's instead of the 52s on my last blazer and got more like 5 or 6 because they had more arch to them. Longer and flatter springs give a better ride and more flex. Tuff Country springs tend to have the softest springs rate for aftermarket options...unless custom made. Do you have your front sway bar still attached? If so, get rid of it. Last edited by blakeduren; 08-10-2010 at 10:01 AM. |
#15 | |
Re: Lift Pics
Why get rid of the front swaybar?
#16 | |
Re: Lift Pics
Here is what is in there now for shims. I don't believe these to be extended length shackles.
I think this last one shows a spacer that was used to correct that geometry. I see your point on coupling the front with bad geometry though. Brake lines are extended with braided lines. I think you can see them in one pic. They may be a little too long with less lift though. I will look into putting on 56" springs, but I'm afraid that it would interfere too much with a hitch (that I need to add also). Quote:
#17 | |
Re: Lift Pics
![]() Last edited by 78 Chevyrado; 08-10-2010 at 03:43 PM. |
#18 | ||
Re: Lift Pics
Thanks for all the input! Levi |
#19 |
The Few, The Proud
![]() Join Date: Jun 2007
Re: Lift Pics
Not a crew cab, but here's my old '87 with a 2" lift running 33's.
Shannon |
#20 |
Re: Lift Pics
#21 |
Re: Lift Pics
#22 |
Re: Lift Pics
#23 | |
Re: Lift Pics
#24 | |
Re: Lift Pics
#25 | |
Re: Lift Pics
