Question about lowering blocks..
68' Chevy truck longbed: flows, 4/6 drop, k&n filter, GMC front clip, and 20s |
yes ... all you need are the blocks and longer U-bolts.
What if?
whats the max you can go on lowering blocks?
2002 red extended cab Silverado 2002 Wheatland yellow Suburban |
But were would you place the blocks? because I have seen trucks with leaf springs that have them and I know that it can't be installed the same way. I want to add a 1in lowering block to level my back with the front.
if you have coils it goes between the rear axle and the trailing arm, (under neath the axle, and above the trailing arm) with longer U bolts
Fabricate till you "puke"
A 2" block is prettyclose to max if you are running 15" wheels.....much more, & you will be below "scrub lines". crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
4 speed, hurst shiftin
put 3 inch drop blocks in .....drop in a 800hp motor, lighten up the front...and put gas shooting nozzles on the rear bumper , i think this will show using the scrub line to its full potential
Shane 1970 Chevy C10 |
LOL! Did you like those fire burnouts from the 60s?
