Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-15-2010, 09:24 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Quick Change Rear?
Who makes a good quick change rear system? I need to be able to take out one rear and put another in in under an hour. Also, whats a strong fairly cheap rearend? To handle me having fun with 300hp/600ftlbs on the street.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-15-2010, 11:50 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Quick Change Rear?
300HP ands 600ftlb?? what ya doing?? Sounds like a turbo diesel?
That's a LOT of torque!!!!! If this is in a heavy vehicle,, have you considered a 9"? I can drop the rear disk caliper / retainers, pop the axles out, remove the 10 bolts and have the centersection out in less than 1/2 an hour. (IF the tires are already off,, I have to drop the coilovers/suspension and get the rear down far enough to get the slicks out from under the quarters)
If you don't have tire clearance issues I bet a 9" will fill the ticket. It would mean your buying two complete centersections, but I think a 9" with a locker would be one of the few street differentials to hold up to 900 ft lb on a continual basis.
AND, you better look AT LEAST a 33 spline axle. Anything less and I think your looking at troubles.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-15-2010, 03:21 PM   #3
thirdstreettito
Resident of Here
Yes, turbo diesel, then I will supercharge it. Price on a built 9"? I am trying to stay VERY cheap.
~Bradley~
Miss having a truck
Old 08-15-2010, 03:31 PM   #4
cdowns
cdowns's Avatar
you should b able to get a real quality built bullet proof for under 5thousand
Old 08-15-2010, 03:43 PM   #5
cableguy0
A solid built 9 inch with two complete center sections ready to go your looking at probably 5k give or take. There is not cheap way to do it. Cheap is unsafe and will yield broken parts and the risk of crashing. If you break something in the rear and it locks up at 100+mph your going to crash and its going to be bad.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-15-2010, 04:00 PM   #6
thirdstreettito
Resident of Here
Whoa! I said budget not debt. That is extremely expensive. Thats more than the truck cost.
~Bradley~
Miss having a truck
Old 08-15-2010, 03:53 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Look at DJ's post in the other thread.
Old 08-15-2010, 04:30 PM   #8
thirdstreettito
Resident of Here
I dont want a locker, Im not rock crawling. This is a street driven truck.
~Bradley~
Miss having a truck
Old 08-16-2010, 02:13 AM   #9
thirdstreettito
Resident of Here
Ok, what about a 10bolt(non quick change)? It will be 2.73 gears. So, all it will need to handle is speed.
~Bradley~
Miss having a truck
Old 08-16-2010, 02:24 AM   #10
BigDan3131
BigDan3131's Avatar
Your not listening, all the torque will still break any stock rearend if you mash the throttle repeatedly.Since quick change is out of the question the just find a Dana 70HD or 80 or even a corp 14 bolt and have it made to work in your ride.
BigDan3131 is offline   Reply With Quote
Old 08-16-2010, 09:01 AM   #11
thirdstreettito
Resident of Here
There is no way the torque can beak it with that gearing. This is for a land speed truck. So Im not going to mash the throttle.
~Bradley~
Miss having a truck
Old 08-16-2010, 11:16 AM   #12
robnolimit
robnolimit's Avatar
For a QC, look on E-bay for used oval track parts. if you thinking 9", look into a floater. Motorstate sells Coleman built 9" housing, axles, hubs, and brakes for about 1200 bucks, then it is really easy to change gears, and safer in a race truck
robnolimit is offline   Reply With Quote
Old 08-16-2010, 05:42 PM   #13
BigDan3131
BigDan3131's Avatar
You should have mentioned the land speed use in the first place
Old 08-16-2010, 10:03 PM   #14
thirdstreettito
Resident of Here
Would a 10 bolt with 4.10 Detroit truetrac and 30 spline moser axles do the trick? And yes, disc brakes too.
~Bradley~
Miss having a truck
Old 08-21-2010, 07:01 PM   #15
mbgmike
We sell Strange Top loaders
mbgmike is offline   Reply With Quote
