Old 08-18-2010, 12:05 PM   #1
bgsnake
bgsnake's Avatar
1962 GMC build input
hey guys.
looking for help on my new project. traded my desert prerunner for this and need to do something about the manual brakes, steering. thinking of using a 1973-87 donor truck/suburban for front suspension and adding the power brakes and steering since cash is tight.
any years i should avoid or try to get?
will rear axles swap over?
thanks for all the help.
bgsnake is offline   Reply With Quote
Old 08-18-2010, 02:35 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 1962 GMC build input
The build part is usually a personal preference...but, I have to say that that is quite the trade.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-18-2010, 11:07 PM   #3
bgsnake
bgsnake's Avatar
i think i got the better end of the deal, but my prerunner was a fully built LT. kind of sad giving up a done project to start another.....
looking for tips from guys that have done the swap and what worked best or lessons they learned.
Old 08-18-2010, 11:58 PM   #4
Captainfab
60-66 Nut
Welcome to the forum
That's a real nice looking '62 you traded for.
Here's a thread that should give you all the info you need for the front suspension swap.
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
The '73-'87 rear ends will work, but they are 1.5" wider. If your GMC has leaf springs, it should bolt right up, but the shock mounts, will be in the wrong location. If your truck has trailing arms and coils, then you will have to remove the trailing arm mounts and panhard bar mount from the original rear end and weld them to the newer rear end.
Old 08-19-2010, 12:38 PM   #5
bgsnake
bgsnake's Avatar
thank you very much. thats the info i was hoping for.
