Old 08-19-2010, 07:07 PM   #1
My72BB
72 Truck Frame vs. Suburban Frame
Did a search and could not find what I was looking for...I posted this question in the suspension section as well...not sure what catagory????
Has anybody done a comparison between a 1972 3/4 Ton 4 X 4 Frame and a 1972 3/4 Ton 4 X 4 Suburban Frame.
I am considering converting my C20 to a K20 and have found a couple of Suburban 4 X 4 donor frames...1/2 and 3/4 ton.
I have heard that frames are same but need to add cab mounts/bed mounts and cut off rear frame horns...
Has anybody actually done this?
Thx...Alan
My72BB is offline   Reply With Quote
Old 08-19-2010, 08:52 PM   #2
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 72 Truck Frame vs. Suburban Frame
73-87 burb frames are different on the rear portion of the frames and im sure 67-72 is the same way. And 1/2 ton frames use thinner metal than 3/4 tons so try to get a 3/4 ton. I would try to find a truck frame unless you don't mind having a flat bed.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 08-22-2010, 12:45 AM   #3
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
OK apparently burb frames are the same as truck frames just longer at rear frame horns. Go down to post 18 and start from there: http://67-72chevytrucks.com/vboard/s...d.php?t=313438
Tony
Old 08-22-2010, 07:35 PM   #4
Mike C
Mike C's Avatar
The Suburban frame has the inner bumper mounts as part of the frame. The truck frame has just straight rails then uses brackets to adapt the bumper. MUCH easier/cheaper/more choices for frame mounted receiver hitch on the truck frame. Most likely their are additional differences on body mounts, spare tire, fuel tank, etc.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-23-2010, 03:03 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
Note, the 1/2 and 3/4 ton frames are the same in thickness! Truck to Suburban, you will have different body mounts and the rear of the frame is different.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-23-2010, 07:53 PM   #6
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I thought they might be the same thickness, but ive always heard that 73-87 1/2 ton frames are thinner and I assumed it was true because it seems like 1/2 ton frames crack around the steering box more often, and I figured the same for 67-72.
Tony
Old 08-23-2010, 09:21 PM   #7
My72BB
Thanks for the input...It helps alot and now I can continue my quest for a good 3/4 ton 4 X 4 Frame.
Alan
