96 Caprice (COP CAR) rear axle with disc brakes
I just picked up a rear axle with disc brakes out af an older caprice. Anybody know how the width will match up. Already did my 5 lug conversion on the fron end to a mid 80's chevy truck. Thanks
Re: 96 Caprice (COP CAR) rear axle with disc brakes
Does the cop car have a ten bolt like the SS impala? Regular Caprices have eight bolts, i was told they wont work.
its a ten bolt.
i put that in my 65 its like a 1 1/2 shorter on each side, if u want to see pic's go to myspace.com/vcofmemphis and there pics of it, it help we out cuz my wheels r so wide, it tucked them in some,
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
Everything is 10 bolt on caprices. The difference is the 4.3L cars generally had 7.5" rears and the 5.7L cars had 8.5" And unfortunately Cop Car does not guarantee 5.7L, many were ordered with the 4.3L for fuel economy. Cop Rears are wider than Impalas. I can't remember the actual dimensions off the top of my head though.
I've got the 8.5" with 4.10's and an Eaton Posi in my Impala and it seems to take whatever punishment I can throw at it. -Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. |
60-66 Nut
I don't know just how wide they are, but it seems that someone here has done that swap, I just don't know who.
Since you have it there, I would just throw a tape on it and measure it. Your original truck rear end measures 62" WMS to WMS. That will give you a measurement to compare to.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-21-2010 at 12:11 AM. |
![]() Join Date: Jan 2010
here is a complete lineup of these rear-ends. i've had good luck with the stock rear in my wagon and it pulls 1.69 sixty foots at 4700+lbs
Chevy 91-92 sedan 1566mm - narrow (all) 93-96 sedan 1566mm - narrow (9C1 - disc & drum & some other drum applications) 1598mm - wide (Impala SS - disc & B4U - drum) Buick 91-96 & Fleetwood 93-96 sedans 1566mm - narrow (all) NOTE: Fleetwood housing is unique to the application - 4-channel ABS provisions 91-96 wagon, all 1642.5mm All 93-96 7.625" (ring gear) housings are 1598mm wide (Chevy sedan only) Sedan housings, in both widths, have the same lower control arm bracket location/spread distance, and will fit any other sedan frame. Wagons have a wider spread distance (approx. 2") between lower control arm brackets on housing, and corresponding wider frame lower control arm mounts. |
#8 | |
I have only 2 4.3 police cars, the other 9 are all lt1 5.7 cars. And all 9c1 4.3 L99 cars came with the 8.5 rear. GM did not use the 7.5 ring for any poice cars. They would not hold up. Soi have found anyway. 93-96 sedan 1566mm - narrow (9C1 - disc & drum & some other drum applications) 1598mm - wide (Impala SS - disc & B4U - drum)
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. Last edited by no moa; 01-28-2011 at 01:16 PM. |
I Got it BAD!
My buddy put a 94 caprice cop car rear in his.. Here is the thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=358328 Fit's perfect. The only problem he has been having is trying to find the shoes for the emergency brake. I guess they are not available anymore. They look like small version of normal brake shoes.
Build Thread: http://www.chevyguys.com |
is there any draw back to a 4 link set up as opposed to the factory set up? my intention is to bag it and get it as low as possible.
Registered Loser
A triangulated 4 link will eliminate the side to side travel of the axle caused by the panhard bar.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. Last edited by creep; 08-22-2010 at 09:24 PM. |
#12 | |
Took a while, but CL came through. $50!
![]() 94 Caprice 3.08 open gears. I wanted a posi unit, but $50 was too good
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#14 | |
Trueman |
#15 | |
#16 |
1996 chevy caprice with disc brakes. it was perfect on steel wheels. but i pulled the rear fenders a little so i can clear reversed wheels
#17 |
I just found a '94 Impala SS rear locally and am thinking of getting it for mine.
Captainfab, can the Camaro calipers be used in place of the Impala's? Don't the Camaro's use a built in e-brake in stead of the crazy mini-drum thing? I have to have an e-brake, but if the price is right, I wanted to see if swapping calipers would be an option.
#18 | |
60-66 Nut
The Camaro caliper mounting brackets (Factory part) that the actual caliper mounts in is different than with the Impala SS calipers. I can check tomorrow and see if the calipers themselves will interchange in the factory brackets.
#19 |
60-66 Nut
Sorry to say that the '93-'97 Camaro rear calipers will not fit onto the '94-'96 Impala factory caliper brackets (cages).
#20 |
I'm not finding a whole lot of info on this swap.
So with the Impala SS rear, do I need to do anything with the driveline or yoke? Are the axle tubes the same size as the C10? So I just need to weld on the perches and bolt it in?
#21 | |
Pretty much a weld in deal make sure to set your pinion angle... |
#22 |
60-66 Nut
Since chopper john put one under his truck, you might send him a PM and see what he has to say.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-02-2011 at 01:15 AM. |
#23 | |
![]() I did, but hadn't heard back from him yet. Sounds pretty basic, not unlike most everything else on these rigs.
#24 |
60-66 Nut
I haven't installed one of these differentials, but it shouldn't be any different than any other differential swap.
You'll have to remove all unnecessary factory brackets from the new differential. Then you will need to weld trailing arm mounts to the new differential in the correct position. This includes the side to side angle for the trailing arms as well as the corrrect pinion angle. Then you will have to fabricate or install a kit to mount the panhard bar on the new differential. The it's just a matter of hooking up the e-brake cables and brake lines.
#25 |
jimmy dean pm sent. i also had to shorten the drive shaft a little, and maybe change the rear u joint
