08-22-2010, 10:10 AM | #1 |
A1 Electric vs Specialty pw's for one piece glass?
I've done a lot of searching on this site, trying to decide which power window kit to use with the Brother's one piece side windows. With the small amount of info I have found, the A1 Electric are good, but I also found a link where a guy really likes the Specialty (SPW) kits.
http://www.webrodder.com/article.php...75&SID=60&CID= I am trying to give the windows some strength in the half down position. . Any suggestions is appreciated. And please don't say "keep the vent windows", I'm past the point of no return. |
08-22-2010, 10:37 AM | #2 |
Its a Truck Thing......
Re: A1 Electric vs Specialty pw's for one piece glass?
I can tell you the A1 is a good kit for the normal windows, cant help with the one piece.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
08-22-2010, 10:05 PM | #3 |
08-22-2010, 10:12 PM | #4 |
Man of Mini-Talents
You might check into Nu Relics. More expensive, but have a life time warranty. I just bought a set of A1's and they seem a little on the spindly side to me.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
08-23-2010, 12:08 AM | #5 | |
We'll see how the A1 unit works. |
08-23-2010, 12:15 AM | #6 |
Man of Mini-Talents
FYI - I found that the rubber "S" type conduit works best to route the wiring between the door and the jamb. I had ordered the stainless braided conduit, but to get the nut tightened inside the jamb requires more surgery than I was prepared to do.
08-23-2010, 12:19 AM | #7 |
I saw those braided ones on the A1 site, they looked like they could be a PITA. What is the "S" type conduit?
08-23-2010, 12:19 AM | #8 |
I have the brothers one piece kit...not yet installed but have done all the mods and purchased the spw kit as recommended by webrodder. The specialty kit is easy to install also and I can see where it's design will help with the one piece kit from brothers...just my 2 cents.
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
08-23-2010, 12:26 AM | #9 | |
edit: I guess I can't post links, but you can copy and paste this on ebays site... 67-68-69-70-71-72CHEVY PICK-UP POWER WINDOW KIT HOT ROD Last edited by NevadaDVX; 08-23-2010 at 12:27 AM. |
08-23-2010, 12:26 AM | #10 |
Man of Mini-Talents
Its a rubber corrugated type conduit piece about 5 or 6 inches long. The openings at each end have 90 degree turns in opposite directions, so it loosely looks like an "S".
I found that it was best to drill the door toward the outside edge because of a bulkhead that angles at 45 degrees - you'll see what I mean when you look in there. I did that hole low and did the jamb hole higher - just below the interior light switch. Then I fished the wire through the same hole in the kick panel as the interior light wire.
08-23-2010, 12:35 AM | #11 |
Hmm, I've never seen those conduits. I was just going to use that plastic flexible stuff. Where it that available? I'm in a small town with very few options for stuff like that.
08-23-2010, 12:40 AM | #12 |
Man of Mini-Talents
You can call them to confirm, but I believe it is what comes by default with the kit. The reason I'm not sure is the guy said he would throw in a different set at no charge. Regardless, you get it from A1
08-23-2010, 12:45 AM | #13 |
Ok cool. I had planned on calling them in the morning to see if there was anything else I would need. I ordered the regulators, switches and relay.
