Old 08-23-2010, 09:37 AM   #1
PLANETGETLOW
1972 C10 - Easy Lowering Options?
I'm pretty sure I have a couple ideas out there but lookin for options.
This truck will eventually be bagged but I want it lowered and slightly tuckin until then.
I figured I could trim or heat the front coils to lower the front and the back maybe just pull a leaf out of each of the springs?
Thoughts/suggestions?
PLANETGETLOW is offline   Reply With Quote
Old 08-23-2010, 10:30 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 1972 C10 - Easy Lowering Options?
DO NOT heat your coils. You will find that to be a very negative topic on here. You can cut your front coil. The starting point seems to be try one full coil and see how it sets. For the rear, since you are leaf spring you can remove the thick overload, and possibly some of the others from the pack. You will want to remove some and see how it sets.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-23-2010, 10:39 AM   #3
PLANETGETLOW
Right on, to be honest I'll just be lowering it for asthetics only. This truck will not be driven or see the road for about 6 months. I just cannot stand seeing it this high.
It will go from this straight to bags which is why I mentioned heating them. I'm aware of how they settle amongst other things but thanks for the reply.
When you say thick overload, you must be referring to the big one on bottom right?
Old 08-23-2010, 11:39 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
do a flip on the rear and cut 1 1/2 off the front.....your never going to get it to look right with those rubber bands on it
Hottrucks is offline   Reply With Quote
Old 08-23-2010, 11:42 AM   #5
PLANETGETLOW
You mean flip the leaf spring shackles around?
Old 08-23-2010, 11:48 AM   #6
Hottrucks
Hottrucks's Avatar
no put your axle on top of your springs....or you can flip the hangers theres lots of ways
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 08-23-2010, 12:46 PM   #7
Hottrucks
Hottrucks's Avatar
jst use the search at the top I'm sure you'll find tons of info on it
Old 08-24-2010, 01:01 PM   #8
PLANETGETLOW
I'll figure it out, thanks for the replies.
