08-23-2010, 04:02 PM | #1 |
Anyone running bags with leaf springs?
I would like to see some pics if possible.
Thanks! |
08-23-2010, 04:03 PM | #2 |
Insert Title Here
Re: Anyone running bags with leaf springs?
I think you would have to mono it
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
08-23-2010, 08:32 PM | #3 |
Happy to be here
Actually you can run it with two leafs and an Air Over Leaf system. At least that's what worked on my 77 anyway.
08-23-2010, 11:03 PM | #4 |
08-24-2010, 09:08 AM | #5 |
Junior Member
You dont ever want to take a multi leaf pack down to a mono leaf... your just asking for trouble. Like the photos above, leave atleast two leafs in there. If you are running any kind of significant horsepower, forget the leafs and go with a four-bar.
08-24-2010, 09:11 AM | #6 | |
Happy to be here
Very good advice.
08-24-2010, 06:20 PM | #7 | |
Did you get that set-up in a kit or piece it together? Gotta start shopping around to find what I need... Thanks! |
08-24-2010, 09:41 PM | #8 | |
08-25-2010, 01:38 PM | #9 | |
How much would a setup like this cost? Like the one above, not a 4 bar/link, just one that would go one a leaf system.. Last edited by tonypaul; 08-25-2010 at 01:39 PM. Reason: opps |
08-25-2010, 12:19 AM | #10 |
Happy to be here
What you see in the pics is my original set up. Everything you see if from Ride Tech except the C-notch and tank brackets. The install was done by my buddies at a shop they used to work at.
To see my current set up take a look at the link in my sig.
08-27-2010, 08:41 AM | #11 |
N2TRUX,
Can you use the bags you have in that location,as helper bags w/a single line into a valve in the bumper to air up we needing to tow? This will be on a '85 |
08-27-2010, 12:27 PM | #12 | ||
A couple of things worth noting.... Ken's 77 w/the AOL set-up & 2 leaves was typically higher than my static drop on the multiple occasions I took measurements. He did have the advantage of going lower when he was parked. I don't know about removing the majority of the leaves & then using the tapered sleeve bag as a set-up for towing. I would verify the specs on the bag w/the manufacturer to get the best part vs. a generic AOL kit. I tow w/o issue but I also have the HD 8-leaf spring pack w/a flip kit & shackles. I'm using a small dbl convoluted bag above the axle which is not recommended for ride quality. I get away w/it because I have air pressure in the bags for towing only; the rest of the time they're deflated (minimal~5psi).
08-27-2010, 09:05 AM | #13 |
Happy to be here
coater- Absolutely. Scoti has been running similar systems on his trucks with great success. I suggest separate lines with schrader valves so you don't have air transfer when loaded.
08-27-2010, 03:14 PM | #14 |
Thanks Guy's!
I also only want to use the bags for towing. I considered to go to 5 or 6" in the rear. I was going to c-notch it just to make sure I had room for towing. SCOTI,do you have separate lines for each bag? Do you have any pics you could share with me? Your setup is what I'm hoping to accomplish. Never lowered any of my squares,always kept them stock with the 10" wheels. I want to lower this one. Thanks again guy's! |
08-27-2010, 08:48 PM | #15 | |
I tried loading my pics for you but something weird is going on & it won't let me. Ok... now it did. The last pic gives you an idea of how they mount. I just attached mine to the bolt-in c-notch & then stitch welded the edges too....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-27-2010 at 09:10 PM. |
08-29-2010, 10:59 AM | #16 | |
08-29-2010, 12:01 PM | #17 | |
I towed N2Billets '68 project 'Tootsie Roll' from shop to shop w/this set-up.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-29-2010 at 12:03 PM. |
08-27-2010, 09:31 PM | #18 |
Thanks Man!! That helps alot. Noticed you didn't use the c-notch on the last pic. That's a good idea welding them to the c-notch.
Thanks again!! |
08-28-2010, 01:15 PM | #19 | |
I bolted my c-sections in (just like a standard install) but mine had the AOL upper mounts welded to the c-section. Once the c-sections were bolted in, I placed some 1" stitch welds around the outside edges on the top, bottom, & sides for an additional margian of safety. And, if you plan to tow but want your hitch out of sight..... http://67-72chevytrucks.com/vboard/s...t=hidden+hitch
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-28-2010 at 01:17 PM. |
08-28-2010, 09:50 PM | #20 |
Damn good job!!! What did you use and the placement of the bottom plate.
Hope you don't mind me copying this. |
08-29-2010, 12:47 AM | #21 | |
The leafs actually control the position & placement of the rear; the bags are soley for additional capacity when required.
